atwater20c wrote:
I am using an output transformer and connecting the red to B+ and blue to plate as indicated by the installation instructions. With the volt meter connected to the radio output terminals B+ and plate as soon as I connect to the transformer input, the voltage reading at the radio goes to zero? I am assuming the output from radio is DC and the input for the transformer is also DC since the transformer has a positive B+ and negative plate.
Umm, (<< means "lookout" lengthy diatribe ahead
Either something is broke/wrong or interpretation of what is being observed is incorrect.
May be a mixture of both...
The measuring device (meter) if it is a digital hand-held it likely has a 1 meg-ohm input resistance. It can measure most DC/AC voltage and draw a very tiny amount of current from the circuit under test.
In some instances this can be miss-leading.There are two versions of the 20c, below are the modern drawings of both variations:
Here is the web site that provided that information:
http://www.atwaterkent.info/Note that how the output to the speaker connections are arranged is different for the two models.
The strange voltage readings seem to agree that the radio is one of those models such as connected erroneously to an output transformer with yield an open circuit reading
Compare the wiring of your radio and/or the model type number which should be on a nameplate attached to the chassis. The wiring should agree to one of those model types.
For the 7570 & the 7960 the output transformer primary should be connected across the "Phone" connections, the plate side getting the blue wire.
BTW the red/blue can be reversed it will still work...
Note the connections for the B+ in reference to how the zero voltage could have been measured.
When measuring voltages in a battery radio where there is no "negative chassis" the B- is the return or reference point. When describing measurements always include both points of measurement.
Be aware, that a DVM can measure tiny leakage voltages yet the measurement will be incorrect.
For example if the grid side of a audio transformer is bad, the grid voltage measured from C+ (not indicated in these drawings and is usually A- & C+ connected together) to the grid of the driven tube can indicate full C- voltage, that is because the grid does not draw current in this instance.
Even measuring the resistance WITH A DVM of a audio transformer can be problematic as the DVM tries to negotiate a combined resistance and a high inductance.
I always recommend using an analog ohmmeter for work on a radio as the meter does draw current and is not confused by high inductance when measuring the resistance of that device.
I also recommend that all observed soldered joints be heated and re-soldered. Solder alloys will suffer from inter-granular corrosion, though will pass DC for a measurement will be problematic at RF frequencies. CAVEAT! some radio parts are made of a thermoforming "MUD" compound, soldering to lugs fastened to this material can cause the material to melt and deform, always loosen that lug and/or heat sink the re-soldering process. Loosen and re-tighten all other mechanically made electrical joints too. dissimilar metal interfaces can also be a problem.
Clean the grey colored oxide off of the tips of the tube pins when bayonet sockets are in use. Use a gritty "Steno" eraser on the blades of the tube socket connections.
Never try to read the grid voltage on the detector, it is meaningless as there is no current available to activate any meter even a DVM.
The use of transistor radio batteries for B+ is not a good idea, the internal resistance of a 9 volt battery is too high and may cause the radio to oscillate.
Never use lower than recommended voltages, the "A" supply for this radio is 6 to 6.6 volts NOT 5 VOLTS!.
Running a 20's era radio on reduced filament voltage depletes the tubes of the thorium coating, although this can be repaired the process does shorten the overall life of the tube. The same result if the tubes are operated with too much plate current for example without a recommended "C" voltage. This fault in the tube can be repaired but again shortens the overall life.
I would highly recommend getting a high impedance speaker, they will always be more sensitive than a modern make-do unless in poor condition. Cones will always sound better than a horn. Does not have to be an Atwater-Kent speaker.
Do not use a power supply that grounds to earth via the electric socket the "A" or the B- in this radio, use the ground as recommended at the radios connections ANT/GND and always as short as possible and never to the electrical outlet. Despite that such a connection may "work", don't. Be sure that no bypass capacitor makes the same connection in any power supply, such a condenser can bring noise into the radio via the "U" ground connection at the electrical outlet.
YMMV
Chas
