Page 1 of 1
[ 14 posts ] |
Author |
docjohn
Post subject: Who made this amp Posted: Nov Fri 25, 2022 4:01 pm |
Top |
John Bartley
Post subject: Re: Who made this amp Posted: Nov Fri 25, 2022 4:24 pm |
Top |
Tom Bavis
Post subject: Re: Who made this amp Posted: Nov Fri 25, 2022 6:02 pm |
I would also say home-brew - since sockets are mounted with screws, and since controls are wired to cover. And the tiny output transformer - almost missed it!
_________________ My web page: https://bit.ly/2rxq4qx
Top |
docjohn
Post subject: Re: Who made this amp Posted: Nov Fri 25, 2022 10:00 pm |
The person I bought it from thought it might be home brewed. Those metal chicken head knobs with engraved letters make me think military, some military equipment from WWII had similar letter markings. All those tube socket bolts, and the other mechanical parts have red paint applied after assembly, a form of early Locktite ? Something I've also seen on miliary equipment.
I've worked out the schematic, it's a fairly basic octal amp. with three inputs and a nice tone stack. The light patch under the Bass and Treble controls suggests to me it may have had a banner with a name etc. Wishful thinking?
Top |
Mr. Detrola
Post subject: Re: Who made this amp Posted: Nov Fri 25, 2022 10:25 pm |
The wiring and overall assembly is way too sloppy to have been factory built, but as the others noted, the fact that it's assembled with screws and nuts is indicative of home brew.
Probably built from a generic schematic found in the back of tube manuals or a magazine article. Since 807's are electrically identical to older 6L6's, the builder may well have used what they had on hand.
_________________ Dennis
Top |
docjohn
Post subject: Re: Who made this amp Posted: Nov Sat 26, 2022 3:00 pm |
From a little more research I've done, it appears it may be an early Soundmaster PA by Hy Bloom in Ottawa Canada. One practice he used was a common Buss bar instead of multiple grounds all over the chassis. Another was those red paint dots indicative of Blooms work. The grill work on the doghouse appears to be the same design as used in his Soundmaster 085 model.
Does anyone have any early information on Soundmaster from Ottawa Canada?
Top |
John Bartley
Post subject: Re: Who made this amp Posted: Nov Sat 26, 2022 5:22 pm |
Top |
docjohn
Post subject: Re: Who made this amp Posted: Nov Sun 27, 2022 5:55 pm |
Here's a picture of a similar amp made by Soundmaster's Ottawa Ont. Canada
Attachments: |
161424908_192654542579587_5271244889226273399_n.jpg [ 318.54 KiB | Viewed 839 times ]
Top |
wazz
Post subject: Re: Who made this amp Posted: Dec Sun 04, 2022 11:41 pm |
Member |
Needs some output iron which may cost you. But the positive is that the output tubes are 807 and you often can get those cheapish. Even compared to the similar 6L6 tubes.
_________________ Reddy Kilowatt says; You smell smoke? Sorry about that!
Top |
dberman51
Post subject: Re: Who made this amp Posted: Dec Mon 05, 2022 12:46 am |
Funny -- that output transformer, small as it is, looks absolutely original. And there is not a lot of room to install anything a whole lot bigger. I'm guessing the amplifier is good for about 20 watts. If you could measure the B+ we could get a better idea of output power.
-David
Top |
ampstamp88
Post subject: Re: Who made this amp Posted: Dec Mon 05, 2022 2:07 am |
Member |
The output looks original to me as well (have more antique amps than radios), looks like someone replaced or resleeved the grid wires since new, but that could be the lighting in photo, too. Once you replace the caps, that little thing could be the loudest little amp in the world with the affordable 807's powering it!
_________________ "How come we never watch Television?" - sonuva TV repairman in the fifties, Mac Rebennack.
Top |
docjohn
Post subject: Re: Who made this amp Posted: Dec Tue 06, 2022 9:18 pm |
Thanks for the replies on this amp. The original output transformer was a two-bolt design, you're correct, not much real estate in there. I had a Hammond 125D in my junk box which I installed it to get the amp functional. After restoration and running on a Variac at 85% the 807 plates see 325 volts at 45ma., so it's putting out 13 watts. The amp sounds fantastic, with nice clear Bluesy tones.
I have an Electrosonic catalogue from 1954/55, listed in it are possibly what the original transformers were, Hammond 68 or 126. Both listed as Heavy Duty. Here's a picture of the restoration under the hood.
Attachments: |
Top |
docjohn
Post subject: Re: Who made this amp Posted: Dec Tue 06, 2022 9:36 pm |
Oh sorry, forgot to mention those grid wires have resistors in them under the hand wired shields. They look original to me, imagine taking the time to hand wire ground shields like that. I liked the technique, so I left them in place. As usual, there were extra electrolytics jumped to earlier leaky electrolytics, often see this in radio restorations as well.
Would have liked to install a Hammond 1750 or 1637 output transformer but there is simply no room for either.
The original two-hole design had a hole spacing of 2 3/8" which seriously limits available replacements. I had to drill another hole to get the 125D to fit, it has a hole spacing of 2 3/4" if memory serves.
Top |
JukeBoxDenny
Post subject: Re: Who made this amp Posted: Dec Wed 07, 2022 1:01 am |
Member |
Kind of reminds me of an old Masco P.A. amp.
_________________ "Multi-Horn Hi- Fidelity" By AMI
Top |
Page 1 of 1
[ 14 posts ] |
Who is online |
Users browsing this forum: No registered users and 5 guests |
