It is currently Oct Mon 21, 2019 4:59 am
 Post subject: Baldwin PC model S amplifier
PostPosted: Apr Fri 17, 2009 3:34 pm
Hi ,
I need a better coppy of a schematic of this amp , would appreciate if some one could point me the right direction .
http://s10.photobucket.com/albums/a148/ ... amber_.jpg .
I want to make some changes ,but would be nice to know what i'm looking at . The previous owner left large muddy foot prints inside . His name was Rex Eveverything :wink: .
Mark
PostPosted: Apr Fri 17, 2009 4:08 pm
I have a Baldwin schematic labeled "PB Amplifier" Model 45 which looks the same as your link, except for the power and output cabling. This amp has pushpull parallel 6L6's in the same circuit.
I have scanned it and could email it........but you don't have an email address in your profile.....
--Chuck
PostPosted: Apr Sat 18, 2009 11:27 pm
Hi Chuck ,
Thank You For The readable schematic .
Mark
PostPosted: May Thu 21, 2009 11:03 pm
Hi ,
Been working on the baldwin amp, wanted to put the huge power transformer to full use ,as it powered all the tubes in the organ .So I modified it from pushpull parallel 6L6G's to PPP 6550 and an AnTek At 1008 toriod output transformer that is good for 100 watts . The amp now uses four 6550's ,two 5U4GB's and a 6SL7.
Heavyer power cords and heyco gorment are on order .
Mark
Here is a link to photo of what the looked like before I traded Rex everything out of two .
http://www.audiokarma.org/forums/showth ... p?t=197798
Here is what they look like now .
 Post subject: Re: Baldwin PC model S amplifier
PostPosted: Jun Thu 13, 2019 11:58 pm
Hey, I know it's been 10 years since you mod'd these amps. Hopefully you can remember how you modified the power supply 4mfd 600vdc caps to what you show being used. Could use any info you'd like to share regarding your project. I have one now with way too much AC leaking into OPT and I don't want to use those huge can electrolytics??? any longer. Thanks.
Chuck, thanks for the 45 scan. There is another schematic of the PC I have that's more accurate and I could send it to you if you'd like. Thanks, Ed.
