It is currently Jul Wed 24, 2019 9:30 am
 Post subject: Heathkit model a7 amp-
PostPosted: Apr Thu 08, 2010 6:08 pm
mornin' everybody!
i found an old amp in my '56's trunk this morning,marked model a7-how can i tell what letter version it is so i can put in the missing tubes and recap?
currently it has 1-12a6, a 12j5 and a 12sh7-3 others missing.
most likely it uses a 5y3 rectifier and another 12 a6.
any help appreciated,phil
I've been doing so much for so long with so little I can now do anything with nothing!
PostPosted: Apr Thu 08, 2010 10:10 pm
According to this site, all of the A7 versions used the same tube line-up except the later versions added a 12SL7 phono preamp. (Note that two of your tubes are not on his list.)
http://www.kta-hifi.net/projects/amp_page/a7amp/a7.htm
You'll like this little amp.
PostPosted: Apr Thu 08, 2010 11:28 pm
thanks dave!
i figured the sockets were stuffed to fill the holes-now i have something to work with.
phil
PostPosted: Apr Thu 08, 2010 11:39 pm
A7B, C, D and E schematic on my web site: http://www.Aduiophile.cjb.net/Audio.html
PostPosted: Apr Fri 09, 2010 1:54 am
philco fan wrote:
thanks dave!
phil
Looks like you might have the "C" version and the website I pointed to is wrong about all having the same line-up.
PostPosted: Apr Fri 09, 2010 4:23 am
no worries dave-i checked the schematic and it didn't match so i figured it was a different letter model.
tom-i printed the "c" schematic and will check it against the amp,thanks for the info.
phil
PostPosted: Apr Sun 11, 2010 2:11 am
hi all,i have this little amp up and running.
after figuring out where the tubes went i put 2 shiney new jan/rca 12a6's in it and a shiney new jan/rca 5y3 rectifier and the other required tubes,some minor chassis work and then fed it with a 10 tube citation III f.m. receiver and out the amp to a 10 " philco[of course] pm speaker and it's thumping away,sounds pretty good for a little amp!
i'm probably gonna put it ebay in a week or so as i don't have any real interest in tube amps so i guess i'll see if anyone else does.
thanks to all that contributed.
phil
 Post subject: Re: Heathkit model a7 amp-
PostPosted: Mar Wed 20, 2019 6:49 am
Here is reviving and old thread!
We just had our local Toledo Hamfest and I picked up one of these small Heathkit A7 amps as well. Interestingly enough mine looks to have the samd odd tube line up as you.
5Y3GT
12J5
12SH7
12SN7GT
12A6
12A6
I do have mine working...though needs a complete service. Did you end up finding a schematic for this version? There is some crude repair work in mine and I wanted to make sure of the component values.
Thanks!
Todd
https://www.youtube.com/user/bastardbus
PostPosted: Mar Wed 20, 2019 2:13 pm
I have two of the same model (A7-C) in the queue. Now where did I put those 12SH7s? Schematic attached below. Bigger copy on my website (click my profile).
PostPosted: Mar Wed 20, 2019 4:06 pm
You know what?
I still have this amp,saw it out in the garage the other day,what a timely resurrection!
PostPosted: Mar Wed 20, 2019 11:44 pm
T
PostPosted: Mar Wed 20, 2019 11:56 pm
Todd, nice to hear from you!!
-David
PostPosted: Mar Thu 21, 2019 12:34 am
-David
Hi David! yeah I have not been on here much lately.
 Post subject: Re:
PostPosted: Apr Wed 17, 2019 10:04 pm
Dave Doughty wrote:
... You'll like this little amp... Dave
Right! Had one a while back... restored it... very good performance... sold it. You can't keep them all!
Cheers,
Roger
Roger Jones,
Thornhill, Ontario
PostPosted: Apr Fri 26, 2019 2:02 am
Heathkit got a lot of use from their stock of war surplus tubes. Besides the 12A6, you'll find 1619, 1625, 1626, and 1629 in various pieces of gear; they were all dirt cheap in those days.
PostPosted: May Sat 04, 2019 9:30 pm
They're nice little amps for what they are. Perfect for a small, cheap radio-phono setup. I know a ham who keeps one connected to a shortwave radio and a decent 12 inch full range speaker for SWL.
