It is currently Aug Thu 05, 2021 6:16 pm
 Post subject: Baldwin Organ Amplifier
PostPosted: Mar Sun 16, 2014 10:50 am
Can anyone identify this Baldwin amplifier? It uses six 6BQ5s, four 12AX7s and a 5U4. I need a schematic to help with the power and audio socket connections. Thanks.
 Post subject: Re: Baldwin Organ Amplifier
PostPosted: Mar Sun 16, 2014 2:15 pm
Hi Johnnysan,
From this e-bay listing it seems that this is a Baldwin 54A amplifier.
http://www.ebay.com/itm/Baldwin-Organ-Tube-Amp-Amplifier-transformers-guitar-6BQ5-/171265614859?pt=Vintage_Electronics_R2&hash=item27e039e40b
Good luck, Peter
PostPosted: Mar Mon 17, 2014 1:28 am
Looks like maybe the Leslie attachment had its own amplifier built on the main amp chassis.
You can easily make a mono bi-amped system with the amp if you don't replace transformers.
If you don't mind replacing the output transformers you can make this a stereo bi-amped system.
For stereo you would have an approximately 14 WPC push pull stereo amp for the bass-midrange then a nearly 5WPC stereo amp for the upper midrange-treble.
Either way you should have enough 12AX7 tube sockets on the chassis to make it happen including a simple crossover.
PostPosted: Mar Mon 17, 2014 3:15 am
Thanks for the information on the model number. Now I just need to find a free schematic.
PostPosted: Mar Tue 18, 2014 3:19 pm
Hi Johnnysan,
Here are some diagrams on Baldwin organ amplifiers, look at the JonsDiagrams.pdf file:
http://www.audiokarma.org/forums/showthread.php?t=197325
It is not on the 54A, but looks close enough. You can trace out the schematics of yours, and probably the connector diagrams in those files would help too.
Regards, Peter
PostPosted: Mar Tue 18, 2014 4:59 pm
A friend in the radio club does organ service; I'll see if he has any Baldwin drawings.
PostPosted: Mar Wed 19, 2014 6:24 am
Hello Johnnysan:
I have the same amplifier in my collection. Its a Baldwin, from a model called an Orgasonic
the chassis # or model # is a 56PL. I am also looking for a schematic,so if you have any luck
please E-mail me. Bob
Users browsing this forum: xmttrman and 4 guests
