It is currently May Wed 27, 2020 1:23 am
 Post subject: GZ33 and GZ37 vs GZ34/5AR4 rectifiers
PostPosted: May Sun 10, 2015 12:33 am
I would like your thoughts. I love the big bottle GZ33 and, with a choke PS, it is (I think) rated at 300 mA and 40 uF. The GZ37 has a (silly) rated 4uF but is still considered a robust rectifier for 6550/KT88 type amps. I do not really trust the data sheets of the 33 or 37 and wonder if the vintage audio community here can add to my knowledge. Biggest question is "do either of the big bottle tubes offer any advantage over the Mullard GZ34 or Sylvania 5AR4?"
This is a NOS vintage tube question only. Scuds and silkworms - like Larry said.
 Post subject: Re: GZ33 and GZ37 vs GZ34/5AR4 rectifiers
PostPosted: May Sun 10, 2015 4:04 am
Why wouldn't you trust the data sheets? They're all rated about the same, 750 mA peak repetitive current, 250 mA with cap input. Maximum cap would depend on the current limiting resistance (power transformer and other resistance before the first cap. The higher the supply voltage, the higher that resistance must be (or the cap size must be reduced) to meet the maximum current limit. The 5AR4 has the advantage of lower heater current - don't sub the others unless you know the heater winding can take 3 amps.
PostPosted: May Mon 11, 2015 2:30 am
Why wouldn't I trust the data sheets? Have you seen a GZ37? Does not 4 uF maximum capacitor seem absurd? Did you even look?
PostPosted: May Mon 11, 2015 3:02 am
The REAL limit is 750 mA peak repetitive current. With a 140 Ohm transformer, 500V and 250 mA, ALL of them should be limited to 4 uF. With lower voltage and current, higher transformer resistance, higher cap values will be fine. There is no straightforward formula to calculate peak current, but SPICE or other CAD programs make it easy these days.
PostPosted: May Mon 11, 2015 3:58 am
Thanks Tom, I will look into that.
