It is currently Jun Sat 15, 2019 10:03 pm
Post New Topic Post Reply  [ 55 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: Heathkit FM4
PostPosted: Mar Sat 31, 2018 10:59 am
Audioman wrote:
Hi all. Changing to a full wave bridge has two advantages. First the hum level will be easier to filter given the same size capacitors and secondly the power transformer will run cooler.
Bob
Why would the transformer run cooler? The peak current is higher, but the average is the same.
-Mark
PostPosted: Mar Sat 31, 2018 7:38 pm
Because half wave rectifiers dc component tend to saturate the core. A bridge does not put dc through the transformer.
PostPosted: Mar Sat 31, 2018 7:58 pm
I'm not sure I follow that. But maybe you meant more than I understood.
Here's more detail and theory:
https://electronics.stackexchange.com/q ... e-rectifie
PostPosted: Mar Sat 31, 2018 8:02 pm
Thanks to the advice, I now have a vintage looking top chassis. I should have thought of that. Vintage is my middle name.
It did not go with out some work though. Thanks for the tip....
John Smith, over and out.
PostPosted: Mar Sat 31, 2018 8:13 pm
Why are there two old caps sideways on top? Is the paper covered one re-stuffed?
Is that rusted tubular thing on the left a tube shield?
PostPosted: Mar Sat 31, 2018 8:29 pm
Yes, its a tube shield. I will try to clean it up. All FM4's I have seen have the same rust.
PostPosted: Mar Sat 31, 2018 8:41 pm
I guess because of horizontal mounting. Most vertical mounted tubes allow excess heat to escape through the top whereas this is cooking that metal and when it cools it condenses moisture from the air causing the rust?
PostPosted: Mar Sat 31, 2018 8:50 pm
Very logical Peter. I was thinking it was the type of metal they used. I like your theory better.
PostPosted: Mar Sat 31, 2018 9:16 pm
john8750 wrote:
...I was thinking it was the type of metal they used. ...
Could be a combination.
PostPosted: Mar Sat 31, 2018 11:14 pm
Thanks. I like your theory very much. Probably the best yet.
PostPosted: Apr Sun 01, 2018 11:10 pm
I am waiting on the new dial cord now. I need to disassemble the front, because there are some loose nuts. I cant reach them. One is for the shaft that holds the tuning cap shaft. It could be interfering with the dial cord operation. And then the whole tuning mechanism needs to be aligned. The dial light is shot. I wont replace it because the unit will not be in an enclosure, and I can see it clearly where it will sit.
PostPosted: Apr Wed 04, 2018 11:34 pm
john8750 wrote:
... Is that rusted tubular thing on the left a tube shield?
On my two FM4s (as acquired), one tube shield was quite clean, but the other was so rusty it was hard to get it off. Tube shield was mostly OK. Scrubbed up to bare metal it went back on easily and is still clean a few years later!
Cheers,
Roger
Roger Jones,
Thornhill, Ontario
PostPosted: Apr Wed 04, 2018 11:53 pm
Those are the original parts, for show off. They are not connected. The new parts are connected under the chassis.
PostPosted: Apr Wed 04, 2018 11:58 pm
Cheers,
Roger
My tube shield don't want to come off either. I thought maybe it was a press fit.
PostPosted: Jul Wed 04, 2018 7:12 pm
I will be back to this project later. Right now have another amp project, Williamson, to work on. Check it out.
Flip has it all under control.
viewtopic.php?f=12&t=338702
