It is currently Oct Tue 15, 2019 4:59 pm
Post New Topic Post Reply  [ 95 posts ]  Go to page Previous  1, 2, 3, 4, 5
 Post subject: Re: Motorola SK14M HiFi Stereo as Done as It Will Get
PostPosted: Aug Thu 16, 2018 4:26 pm
For what it's worth, your turntable is a VM made unit. Yours looks to have very nice cosmetics, you may want to think about just swapping the guts from a more plane jane looking VM to get yours up and going. I have a couple extra should you ever decide to go down that path, but it sounds like that's not in the near future.
Either way, I always thought the Motorola changers of that era were some of the nicest looking units ever made. Even non-functional I'd take it over any other brand!
PostPosted: Aug Thu 16, 2018 4:38 pm
Steve, that sure looks like a VM turntable. Should be able to fix it easily!
PostPosted: Aug Thu 16, 2018 4:44 pm
I remember buying a motorola changer just like that at Dayton Hamvention.
PostPosted: Aug Fri 17, 2018 12:18 am
the style of the changer is very nice. it is right up there with the nipper dog changer in my RCA SHF-5.
thanks for all the offers, but i have absolutely no desire to do any turntable work or spend the money and time on restoring one.
until one spends the money to rebuild the idler, then perhaps a new cartridge, spare needles, and although i'm good for the cash part, the money and disliking to work on it is absolutely not worth it to me.
i won't use the turntable anyway.
i will just enjoy the sound that pumps from it via my computer, cd player, or tuner.
steve
PostPosted: Aug Fri 17, 2018 8:37 pm
here are four pages (at the time this link was posted) that completely, whole heartedly, fundamentally, thoroughly, fully, utterly, unconditionally, and exactly describe why I despise working on and refuse to work on turntables anymore.
I could even add to it with more experiences as I don't believe it even touches on cartridge issues.
I've done TT restoration many times in the past and can do it quite well with success, but not without pain, agony, and frustration.
just like philco, turntables (and any kinds of hobby frustration) are no longer a part of the equation on the Rabbit's bench. I don't mind it when the hobby becomes "work", but when it becomes frustrating, irritating, and cantankerous, those days of putting up with it are done.
I'm just getting older 8) .
viewtopic.php?f=9&t=342531
this nails it folks ^^.
steve
PostPosted: Aug Sun 19, 2018 4:16 pm
I found it. I think its the same
Thing is I remember paying $20 because I thought it was so attractive with the chrome.
I can see if its easily lubricated and restorable to operation, in case of interest. All I would want is my $20 back.
PostPosted: Aug Sun 19, 2018 7:28 pm
hi steve,
i certainly appreciate that, but i'm satisfied with the set as it is.
thanks again,
steve
 Post subject: Re: Motorola SK14M...Story...and Schematic Needed...(Sigh)
PostPosted: Aug Sat 25, 2018 10:40 pm
rocketeer wrote:
True, but I run a bucking transformer as much for the chassis components, including the transformer, as for the tubes... Larry
All of my mix-and-match stereo tube amps run off bucking transformers for that reason... and we have a 125 VAC supply They are variously P-P ECL82, 6V6, 6BQ5, 6L6, KT66 and EL34.
Cheers,
Roger
Roger Jones,
Thornhill, Ontario
PostPosted: Aug Sun 26, 2018 1:33 am
The only time I run a bucking transformer is when the line voltage is higher than the specified operating voltage as in my opinion thats the only time it is needed.
PostPosted: Aug Sun 26, 2018 4:43 am
i absolutely love my new power transformer up on the pole.
114-117 VAC all day/night long.
steve
PostPosted: Aug Mon 27, 2018 11:49 am
Very nice.
Where I live at least 5 homes share the same pole transformer so line voltage can vary a bit.
Seems a little more stable in the newer trailer though versus the old one my dad and I lived in.
PostPosted: Mar Tue 26, 2019 2:15 am
Hey man, I’ve had the Motorola S14m cabinet for awhile dying to pair it with the sk14m and an additional S14m cabinet to complete my home sound system. If you are ever interested in selling please let me know. They’re really well made beautiful pieces.
PostPosted: Mar Thu 28, 2019 10:07 pm
nope, not interested in selling, but thanks for asking.
Man
PostPosted: Mar Fri 29, 2019 9:17 pm
Tube Radio wrote:
The only time I run a bucking transformer is when the line voltage is higher than the specified operating voltage as in my opinion that's the only time it is needed.
Each to his own. I don't like running 6.3 volt heaters as high as 6.85 volts but, IMHO, the effect of a higher B+ is rarely a problem as long as the radio/amplifier has been properly recapped.
Cheers,
Roger
Roger Jones,
Thornhill, Ontario
PostPosted: Mar Sat 30, 2019 12:37 am
I once ran a Zenith K-731 radio at 150Vdc B+ as I did not add a dropper resistor after replacing the selenium and the volume would never go exactly to zero.
All depends on the circuit.
I once had a push pull 6BQ5 amp I built using a Hammond transformer which had a 115 volt primary. Within about a year or two it cooked the 6BQ5 tubes as it ran on 120Vac. Installed a 5Vac transformer to buck the primary and never burnt up another set of tubes.
