It is currently Jun Sat 15, 2019 10:07 pm
 Post subject: PP Throttle Resistors.
PostPosted: Jul Fri 13, 2018 2:52 am
I keep running across something I don't understand.
If you look at the output circuit of a Capehart 115P2-BQ see here http://bit.ly/2NbiUAT You'll notice there is a driver transformer T3 driving the grids of four 2A3 output tubes. Now if you look closely one of the output tubes in each section has a throttle resistor. see R117 & R118 both are 510 ohms.
So looks like two of the tubes would see the full signal from the driver transformer and the other two would see a slightly lower signal. This same design pops up in UTC 45/2A3 amplifiers as well, see here for example http://bit.ly/2NcEbKz looking at R7 & R8 valued at 2500 ohms each, and in another UTC circuit they come in at 2 meg ohms.
Now I haven't heard a real good explanation why you would need or want to throttle one of the output tubes in each section? One person did tell me that it wasn't uncommon for engineers to put in design flaws to trip up those who would copy their work. That may or may not be true. But the fact that I've seen this identical circuit from different manufactures makes me think there is a legitimate purpose for their existence.
Thoughts ideas?
 Post subject: Re: PP Throttle Resistors.
PostPosted: Jul Fri 13, 2018 4:00 am
It would help if I could see the schematics but the links you posted don't allow it.
PostPosted: Jul Fri 13, 2018 4:12 am
Audio power tubes in push-pull parallel will sometimes oscillate automatically. Slightly different values, either in grid or plate circuits will prevent this.
DG
Workin' my Gramophone in a smartphone world.
PostPosted: Jul Fri 13, 2018 4:22 am
The problem most likely is on your end. radiomuseum.org and pintrist are very common and readily used websites on the internet. And the links work fine for me. But yes they do require membership. These are just the easiest way I have to post images.
There is a world of wealth here as far as being able to reference image data. I highly recommend investigating in using them.
PostPosted: Jul Fri 13, 2018 4:30 am
DG
Preventing Parasitic oscillations does seem like the most realistic answer. Thanks for your reply.
PostPosted: Jul Fri 13, 2018 5:09 am
Pardon me but the "problem" is they require membership.
PostPosted: Jul Fri 13, 2018 6:27 am
"throttle resistor" Interesting term.
PostPosted: Jul Fri 13, 2018 6:45 pm
As a member of radiomuseum, every time you download
a schematic, you use up a portion of your membership allotment.
You build up your allotment by uploading things they want, or
by writing a review.
When someone has a question on this forum and references
radiomuseum material, why should responders use up their
allotments to reply ?
de
VE7ASO VE7ZSO
Steve Dow
ve7aso@rac.ca
PostPosted: Jul Sat 14, 2018 4:23 pm
These are known as "grid stoppers" and yes, they are to prevent parasitic oscillations. Resistors and/or inductors are almost always needed with parallel power tubes.
PostPosted: Jul Sun 15, 2018 1:06 am
A 1k ohm 1 watt resistor in series with each 2A3/45 grid would be the modern standard .
A small value inductor in series with each plate would be even better , seven turns of a number
16 solid wire loosely wound around a 3/8 inch dowel rod about 2 inches long and slid of the dowel
will keep them from oscillating ,
Mark
PostPosted: Jul Sun 15, 2018 1:15 am
They allow non members to request the print by email... a quick little step
PostPosted: Jul Sun 15, 2018 3:09 am
Mark
PostPosted: Jul Sun 15, 2018 3:20 am
I really like amplifiers designed by a transformer company. :mrgreen:
de
VE7ASO VE7ZSO
Steve Dow
ve7aso@rac.ca
PostPosted: Jul Sun 15, 2018 6:45 am
Thoughts ideas?
The 2M is and old way of saying 2 K ohms .
Mark
PostPosted: Jul Sun 15, 2018 6:56 am
Yep, the upper case M is the same as the Roman numeral for 1000. The lower case m stands for meg.
Occasionally this: ω will show up in a schematic, it is the lower case of Ω.
PostPosted: Jul Sun 15, 2018 7:56 am
Cant see ALL schematics. however the Pinterest link leads to some
ripe language graphic not allowed here.
Have a feeling that transformer characteristics (or lack of)
Radiotron Designer's, p580-581, composite curves , type 45 and 2A3,
need tweaking.
With the parallel driver tubes, in class AB1,
bias on a 2A3 is -62 volts. At part of the cycle
the peak signal wont (shouldn't) exceed the bias.
Were the grids in parallel, one tube might start
causing plate current to change, before
the other, because no two tubes are exactly
similar. This on a overload trying to drive
the stage AB2.
de
VE7ASO VE7ZSO
Steve Dow
ve7aso@rac.ca
PostPosted: Jul Tue 17, 2018 4:03 am
With all those transformers, the big old amplifiers were HEAVY! Mark, what amplifier is the second schematic of? It looks to be in the 250-300 watt rating.
RCA liked to put stopper resistors in series with each plate, in their PPP amplifiers; typically 47 ohms at 1 watt each. They also served as fuses, protecting the output transformer if one of the tubes f!ashed over.
PostPosted: Jul Wed 18, 2018 9:29 pm
http://www.bunkerofdoom.com/xfm/UTC_1936/UTC1936.pdf page 6
It is a 500 watt modulator .
http://photobucket.com/gallery/user/bat ... nBn/?ref=1
http://photobucket.com/gallery/user/bat ... w==/?ref=1
I have an affinity for utc transfomers , Arch-68 bought my pair LS-58 frome me is why he is curious about the the grid stoppers and PPP amps
The LS-57 amp was built with two LS-57 and two UTC chokes that i got from Alan Douglas .
Modern amps only need an input transfomer or an interstage transfomer with all the gain with a preamp or even CD player has
I have atarte a PP 300B amp with LS-55's but one of them is bad and have had to put the project on hold do to that and health problems .
Mark
Mark
