It is currently Jun Tue 02, 2020 5:29 am
 Post subject: Reel to Reel Pinch Roller Tire Replacement
PostPosted: Sep Tue 11, 2018 9:58 pm
I have an exact replacement tire on the way from a reliable source for a R2R pinch roller. I want to try replacing the tire myself as opposed to sending the pinch roller out to be rebuilt.
I think...
(1) cut the old tire off
(2) freeze the roller
(3) warm the new tire (no direct heat or high temps)
I should be able to 'slide' it on, right? Any other methods, tips or tricks here?
 Post subject: Re: Reel to Reel Pinch Roller Tire Replacement
PostPosted: Sep Tue 11, 2018 11:18 pm
I've never replaced a tire on a pinch roller but your plan sounds like a reasonable one. Let us know how it works out if you go that route or another one.
PostPosted: Sep Wed 12, 2018 12:44 pm
The only pitfall that I imagine is what if the metal "wheel" has grooves around it? Hopefully it is just a interference fit.
PostPosted: Sep Wed 12, 2018 1:40 pm
I always send this kind of thing to VM (Gary stork). There is also Terry's Rubber Rollers.
My concern would be getting the wheel to run true......for example, I can imagine having to "true it up" after mounting to the metal base.
The fact that you were able to buy the part gives some hope that your approach will work.
PostPosted: Sep Wed 12, 2018 1:45 pm
where did you buy the replacement? it seems odd they would make it separately and sell without clear instructions as to how to install
I would agree with you but there's no point in both of us being wrong
PostPosted: Sep Wed 12, 2018 2:39 pm
Bought from Just Audio Repair Center via Reverb.com. I did see a few different vendors selling just the tire, so maybe it's a friction fit as mentioned above and fairly simple. I'm willing to give it a try.
https://reverb.com/item/13501727-teac-a-3300sx-reel-to-reel-pinch-roller-tire
PostPosted: Sep Wed 12, 2018 5:10 pm
I would have thought that glue would be involved.....
PostPosted: Sep Thu 13, 2018 2:48 pm
In this one instance ( a pinch roller) you can probably get along without the glue if the fit is reasonably tight. The roller is passive, not driving any other mechanism. All that is needed is enough adhesion so that the bearing resistance (very small) can be overcome.
John Stone
PostPosted: Sep Thu 13, 2018 3:05 pm
I expect the new rubber today and will update here what I find. Thanks all.
PostPosted: Sep Thu 13, 2018 11:24 pm
Good and thanks. All of our machines are getting long in the tooth...
PostPosted: Sep Fri 14, 2018 12:36 am
Well that was easier than I expected. Removing the old tire and cleaning up was the majority of the work. The new tire went on with a little wiggling and no heat/cold. Very good grip and no slipping. So this may not be a good example of a DIY refurb of a pinch roller as this one seems to be lacking any of the complications some of the other types out there might bring.
PostPosted: Sep Fri 14, 2018 12:42 am
Good to know. I have an A-2300SD as one of my TEAC decks.
PostPosted: Sep Fri 14, 2018 1:47 am
Great machines. Built like tanks and run forever. This one was a cosmetic mess - it had years of nicotine that took many hours to clean. But it was apparently part of someones system that smoked a lot yet listened to very few tapes as the heads are near perfect. It came with Teac NAB adapters that had to be gently un-stuck, and yellow (once gray) original Teac cables. This one I'm keeping.
Thanks for the input all!
PostPosted: Sep Sat 15, 2018 1:46 pm
I have a Teac A6300. I love mine.
PostPosted: Sep Sat 15, 2018 3:44 pm
The “A” series are much more robust than the “X” series. I have and have had many different models with the first being an A-4010. Still have several.
PostPosted: Sep Sun 16, 2018 8:33 pm
Hello Mbear,
great news and repair well done I have few old machines but my classis is my later 60s akai reel to reel and have a few sony's
Sincerely Rich
PostPosted: Sep Sun 16, 2018 9:21 pm
Thanks Rich, all,
Now on to find some 10.5" NAB reels and maybe some ATR brand tape.
I've had a few and my favorite was an A-3340S, but gave it away years ago to a family member. But don't really have a need for 4 channel these days, or really need the 15ips.
PostPosted: Sep Sun 16, 2018 10:58 pm
mbear,
yes those darn reels are sure getting spendy .
PostPosted: Sep Mon 17, 2018 7:02 pm
mbear2k wrote:
Thanks Rich, all,
Make sure the Teac can bias and erase ATR tape, which is very hot (+9 I believe). Maybe check with a Teac forum to see if anyone has experience with it. ATR tape is costly and it would be a problem if it turns out you can't use it.
-David
PostPosted: Sep Mon 17, 2018 7:41 pm
David - good point. I will check in to that.
