Page 1 of 1
[ 11 posts ] |
Author |
1968rt
Post subject: Hole in speaker enclosure Posted: Nov Thu 01, 2018 12:07 am |
Member |
Joined: Jan Mon 24, 2011 7:21 am Posts: 778 Location: saint clair shores, michigan
I bought this Argosy enclosure a while back. Someone put a small speaker in it using a baffle. I am putting in this 12" Utah coaxial. The rectangular hole at the bottom of the enclosure makes me wonder what it is for. Is it a port or an opening for a horn speaker? What puzzles me is that the hole is at the bottom of the enclosure, to me indicating a port. Most midrange or tweeter speakers seem to usually be situated toward the top of the enclosure. Can anyone set me straight?
Attachments: |
_________________ Invisible airwaves crackle with life Bright antennae bristle with the energy - The Spirit of Radio
Top |
badwaxcaps
Post subject: Re: Hole in speaker enclosure Posted: Nov Thu 01, 2018 12:13 am |
Joined: May Thu 26, 2011 5:58 am Posts: 3992 Location: Capon Bridge, WV
Most likely a port. It wouldn't do very much as most ports require a tuned duct to properly radiate bass notes. Thats a simple explanation. I'm sure more learned members can expound on it.
_________________ "Those are my principles and if you don't like them.. well, I have others"
Top |
lorenz200w
Post subject: Re: Hole in speaker enclosure Posted: Nov Thu 01, 2018 12:44 am |
Joined: Jan Mon 16, 2012 4:15 pm Posts: 5922 Location: Near Brandon, Iowa
https://en.wikipedia.org/wiki/Bass_reflexEarly incarnations of this speaker concept didn't use an internal tube. I have a 1937 Motorola 10Y1 with nearly exactly the same configuration: sealed speaker enclosure, with 12" speaker above a rectangular port cut in the sound board below the speaker.
Top |
Dutch Rabbit
Post subject: Re: Hole in speaker enclosure Posted: Nov Thu 01, 2018 1:00 am |
Member |
Joined: May Sun 13, 2012 8:12 pm Posts: 12736 Location: Central PA 16801
I too have a few enclosures that have this rectangular "port".
steve
_________________ You have enemies ? Good. That means you've stood up for something, sometime in your life. -Churchill
Top |
wazz
Post subject: Re: Hole in speaker enclosure Posted: Nov Thu 01, 2018 1:11 am |
Member |
Joined: Jun Wed 08, 2011 2:33 am Posts: 9538 Location: Ohio 45177
No horn has been there due to the absence of mounting holes visible. I would say that after you put in the damping materials you could always experiment and see if it sounds better with the hole covered or open. But also if it was scientifically designed it's size might have been determined with a specific driver in mind. But the fact is that alot of old speakers were cut and try or a compromise design, anyway.
_________________ Reddy Kilowatt says; You smell smoke? Sorry about that!
Top |
Chas
Post subject: Re: Hole in speaker enclosure Posted: Nov Thu 01, 2018 1:33 am |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 14396 Location: S. Dartmouth MA 02748-1225 USA
Ya, port is most useful so long as the enclosure is sealed. If the enclosure has an open back there may be slight loss in bass response. probably not even noticeable.
In my teens I made enclosures for friends. Fully enclosed, fiberglass lined had a port opening based on the remainder of sq.in. of the speaker diameter incised into the square of the speaker diameter. about 31 sq. in.They were quite effective using cheap 10-12" speakers. Friends had only 5 watt amps so it worked well.
YMMV
_________________ Smith's Ale Gives Strength, Smith Bros. Brewers, New Bedford MA
Top |
1968rt
Post subject: Re: Hole in speaker enclosure Posted: Nov Thu 01, 2018 4:04 am |
Member |
The enclosure has a back, and also fiberglass insulation.
Top |
radiotechnician
Post subject: Re: Hole in speaker enclosure Posted: Nov Fri 02, 2018 2:46 am |
Joined: Sep Thu 23, 2010 6:37 am Posts: 11812 Location: Powell River BC Canada
When the port works right, the sound from it reinforces the sound from the cone. You can play with the port size making a sliding panel that changes the area.
Top |
AuroraOldRadios
Post subject: Re: Hole in speaker enclosure Posted: Nov Sun 04, 2018 3:19 am |
Joined: Jul Sun 09, 2006 3:11 am Posts: 6485 Location: Aurora, CO 80013
lorenz200w wrote: https://en.wikipedia.org/wiki/Bass_reflex Early incarnations of this speaker concept didn't use an internal tube. I have a 1937 Motorola 10Y1 with nearly exactly the same configuration: sealed speaker enclosure, with 12" speaker above a rectangular port cut in the sound board below the speaker. My 12Y1 has the same thing. A previous owner replaced the grill cloth and backed it with cardboard. They didn't cut holes for the speaker and port.
Attachments: |
_________________ Me transmitte sursum, Caledoni! Dan B
Top |
Tube Radio
Post subject: Re: Hole in speaker enclosure Posted: Nov Wed 14, 2018 5:44 am |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 20401 Location: Warner Robins, GA
I have a mid 50's Zenith console that has one of those ports which I bought several years ago.
Original speaker was shot so I put in a vintage 12" speaker (forget brand, but it isn't one of the well known ones) and a better cone tweeter.
The speaker when driven by an external amplifier (amp section being reworked into a higher powered amp while keeping the tuner fully functional) sounds great with excellent bass response.
Top |
COM-NAV-ECM
Post subject: Re: Hole in speaker enclosure Posted: Nov Wed 14, 2018 1:51 pm |
Member |
Sorry, broken link. Please remove this post, thanks.
_________________ 1970's Avionics Tech, USN Attack Squadron 147, "ARGONAUTS" A-7E A/C
Top |
Page 1 of 1
[ 11 posts ] |
Users browsing this forum: No registered users and 5 guests |
