It is currently Mar Thu 21, 2019 6:47 am
Post New Topic Post Reply  [ 32 posts ]  Go to page 1, 2  Next
 Post subject: Of all the stupid things...
PostPosted: Dec Tue 04, 2018 11:41 pm
I didn't see a category for stupid stings, so I'm taking a chance I can post it here. My buddy bought himself a nice Sherwood S 5500 II amp got it today. So, he plugs it up and runs it for 20 minutes with no speakers attached. Then, while running, he proceeds to begin hooking up speakers, hooking one leg to the 8 ohm connection and the other to the 4 ohm connection. Immediately one of the 7868 output tubes flared up and was GONE... history... as in kaput. Instead of my risking my friendship with this good buddy rubbing his nose in it, I'll leave it to you guys to opine as to what he has left of an amplifier now, as he had to go to work and has to spend 8 hours on the job wondering what he will come home to.
 Post subject: Re: Of all the stupid things...
PostPosted: Dec Wed 05, 2018 12:21 am
Unless the Asians or Russians make that tube, and they may, he could be in for a nice set of new tubes for as much or more than the amp, I suppose.
PostPosted: Dec Wed 05, 2018 12:25 am
He's already waiting on a quad set of NOS Soviet tubes. It's the output Xformer I'm worried about.
PostPosted: Dec Wed 05, 2018 1:02 am
I'm not so sure that hooking up one of those speakers, the way your friend said he did, would have caused that tube to fail. What about the other tube on that channel? Those tube amps with output audio transformers were built like tanks and it would take a lot more then just hooking up an 8 ohm speaker between the 8 ohm and 4 ohm connections to do all that damage. That's just 4 ohms, no different then hooking up a speaker between the 4 ohm and ground connections. Many speakers say that their 8 ohms but if you actually ohm them out with an ohm meter, more likely they'll show around 6 ohms. I get the feeling that there's more to this story then what was said by your friend or what he understands about the situation. It could be that with all of the physical jostling around while the amp was on may have stressed out an old and tired tube to the point that it just gave out right then and there.
Michael Feldt
www.indianaradios.com
PostPosted: Dec Wed 05, 2018 4:16 am
Running the amp without speakers is unlikely to cause a problem. Driving it into clipping without a load would likely arc over a transformer or tube socket. A tube with grid leakage might take a while to run away - it gets worse as it heats up. A red-plating tube would take a few minutes to overheat an output transformer, though the fuse would probably go first.
PostPosted: Dec Wed 05, 2018 4:21 am
there is either more to this story or the tube had a bad case of grid emission or a catastrophic short.
:arrow: :arrow: *some* of the new production 7868 tubes have fatter pins than original USA made 7868 tubes.
I never experienced this, but I was told about it in someone's horror story within my circle.
when these soviet fatter pinned tubes are placed into the sockets, they will stretch the metal contacts.
have him make double darn sure that the pin size of the soviet tubes match the diameter of the original tubes.
again, I was told this and never experienced it since I've only ever used USA 7868 tubes.
read this post:
http://www.antiqueradios.com/forums/vie ... w=previous
I absolute loved the sound of every amplifier that I ever repaired/restored/heard that used 7868 tubes, but they are very expensive, driven hard, usually weak/need to be replaced, and are very prone to grid emission. I had a few NOS tubes red plate right out of the box. the problem followed the tube in several perfectly restored amplifiers.
steve
PostPosted: Dec Wed 05, 2018 4:29 am
The Sherwood 5500 uses a rather complex output transformer
secondary feedback system that might have gone into oscillation
by not hooking it up as instructions say.
I seem to remember that amplifiers with an 'idiot' speaker phasing
switch and feedback loops like this one gave trouble back in the day.
Anyway, here is is the schem of the output.
Tubes blown ? I'd rather worry about a flashed output transformer .
That used to happen a lot, and while not killing the channel, forever thereafter
they never quite sounded the same.
de
VE7ASO VE7ZSO
Steve Dow
ve7aso@rac.ca
PostPosted: Dec Wed 05, 2018 4:34 am
8 Ohm speakers measure "around 6 ohms" because that's the RESISTANCE whereas the 8 Ohm rating is IMPEDANCE (at frequency). They're not the same thing.
While the impedance ratio should be about the same wiring them between the 8 Ohm and 4 Ohm taps they're not electrically the same because of where the feedback tap is taken off which, of course, is (usually) referenced to ground. Exactly what the results would be I can't say but it surely won't work as intended. Seeing as how the amp in question self destructed I'd guess some catastrophic instability ensued.
PostPosted: Dec Wed 05, 2018 5:28 am
I trie posting a photo of the speaker terminals because they really are confusing. Upon trying thay it all came back to me. Posting photos on this site is hopeless.
PostPosted: Dec Wed 05, 2018 5:58 am
I own two of these amplifiers and it's actually quite easy to make a mistake with speaker connections if youre not familiar with them.
Your friend needs to give this to someone that knows what they are doing if they didn't destory the O/T.
PostPosted: Dec Wed 05, 2018 6:12 am
I have every confidence it will be destroyed. He's a good auto mechanic but approacheseverything else like a bull in a china shop. I've been teaching him electronics for 20 years but have yet to even convey the concept of voltage.
PostPosted: Dec Wed 05, 2018 9:57 am
I always teach voltage as if it was height. A 6' person is say 6 volts "above ground" or POSITIVE. His feet are zero, his knees are 2' above ground. Put him in a hole 6' deep and his feet are NEGATIVE 6volts with RESPECT to GROUND. His knees are what... minus 4 volts, his head is now ZERO volts. He is still 6 ft tall, but can be measured many ways. This is the concept of BIAS voltage too.
Mark Oppat
PostPosted: Dec Wed 05, 2018 10:01 am
I just want to know why he ran it for 20 minutes with no speakers connected? What was the point of that?
The next time you talk to him, you should tell him that tube amps should never be operated without a speaker load connected
William
PostPosted: Dec Wed 05, 2018 4:34 pm
I had an S5000II from 1968 to 1982 and it did this repeatedly. It first suffered a "combustion event" while in the hands of its original owner, a friend of my parents. He gave it to me, and I rebuilt the output section and used it for several years. But I always had to be watchful for another event -- a loud click and a low hum. Kill the power immediately and it would be OK, and then find which 7868 suffered the G2 to G1 short. This happened four or five times over the years. Once I didn't catch it in time and another combustion event occurred. This time it was into the dumpster.
I think it is a combination of 7868 design, weird angle of installation in the S5000II, and possibly excessive G2 dissipation. It's not a good design although it's an excellently sounding amplifier when working.
-David
PostPosted: Dec Wed 05, 2018 4:59 pm
Tom,
"Yes, yes, yes and yes". I have repaired a few amplifiers that had arced output tube sockets. This forum is what told my why and then it became clear. Lucky for me, they were point to point amplifiers not printed circuits.
Just too many variables here...
PostPosted: Dec Wed 05, 2018 7:10 pm
Posting pictures...
1. Find your picture and resize it to no more than 800p on the longest side; file size no larger than 256 kb.
2. Scroll down to the "upload attachment" window.
3. Click browse.
4. Find your picture and click on the file name.
5. Click "Add the file".
6. Put your curser where you want the picture to appear.
7. Click "Place inline".
8. Done deal.
PostPosted: Dec Wed 05, 2018 9:17 pm
I have already scaled the photo I want to post. It's 600 pixels on the longest size and the file is 92.7kb and it is a jpeg. Like I said--I learned years ago that trying to post a picture on this site is hopeless. It's too big, so you size it EXACTLY like they say, then it's too small. Or some othe stupid reason. None of it has ever worked or ever will work.
PostPosted: Dec Thu 06, 2018 1:10 am
One reason I know of that will stop a picture from being posted, even if it less the 800K
and one dimension is less than required, is to have the name contain anything but letters.
BiGpicture OK
BiG/Picture Nope
de
VE7ASO VE7ZSO
Steve Dow
ve7aso@rac.ca
PostPosted: Dec Sat 08, 2018 2:27 pm
Rename the extension jpg.
kb3wbb
PostPosted: Dec Sun 09, 2018 4:03 am
It sounds like a cool amp to have, but if they have a tendency to blow up and eat expensive tubes, I will stick to my Fisher.
