It is currently Jul Tue 16, 2019 7:35 am
 Post subject: KLH 20 thumping problem
PostPosted: Dec Mon 17, 2018 3:28 am
I have a strange problem with a KLH 20 stereo. The set works properly until I put it into mono, then I get a low frequency thump in the speakers. I can disconnect the speakers and it's still there. And move the switch to stereo and it's clean. You can see the wave slowly build up when you switch it to mono. It works in both channels.
The signal is clean before C100, and then a big sine wave at C102. The -13 volts is clean, but reads low at -10.8. The resistor feeding the -13 volts is good, so maybe something is drawing a bit too much current, but it still works in stereo.
 Post subject: Re: KLH 20 thumping problem
PostPosted: Dec Mon 17, 2018 12:39 pm
Try shorting the inputs to ground and see if the problem still occurs. If not, you're picking up some kind of crud on one of the input lines. You didn't mention if this occurs with or without anything connected to the INPUTS. It appears that the inputs sort of just "float" here unless something is connected to them.
I'd also scope the power supplies and see if there is excessive ripple present.
EDIT: you stated ... I get a low frequency thump in the speakers. I can disconnect the speakers and it's still there
You mean the speakers thump if they are disconnected??? 8) :wink: sorry, someone was bound to say it. I got there first.
www.bbtvtestequipment.com
PostPosted: Dec Mon 17, 2018 3:42 pm
OK..so it's on the scope when the speakers are out of the circuit?
Some questions to try to nail this down...
Can you hear it thru good headphones?
Does it repeat in a cyclical manner?
Does it do it on all input functions?
Interesting that it only occurs when you bridge the channels with the mono/stereo switch...which really doesn't introduce anything new to the circuit.
PostPosted: Dec Mon 17, 2018 4:44 pm
Yep shorted the inputs and it still happens.
PostPosted: Dec Mon 17, 2018 5:06 pm
Yep, the signal is there at the Record Out RCAs. It takes a few seconds to show up. If you switch it from mono to stereo then to mono, it takes about 1 1/2 seconds for the sine wave to fully develop.
There's alot more to the schematic than what I posted, this is just the preamplifier. KLH attenuated the AUX input signal and then amplified though these 2 transistors. Since there is no feedback from the output transistors to the preamp, I left that part out.
I haven't tried phono, don't remember hearing it on FM, it does it on AUX mono, and AUX stereo when switched from stereo to mono.
The schematic shows 8 electrolytic capacitors on the input board, but I only see 6. I've replaced them all, with the correct values, and rechecked the polarity.
Here's a picture of the board before I replaced the capacitors. It's a jungle in there.
PostPosted: Dec Mon 17, 2018 5:10 pm
Let's try a different approach. Hook your speakers back up and leave them there ... running the amp without a load is probably not a great idea anyway.
First, let's see if both channels are working. Switch it into stereo and put a signal into L and R and verify that both channels have an output. If not, you have probably found the problem.
Next step, if it passes the L/R output test .... switch the amp into the MONO position and see if it thumps with signal in but turned down. btw, what frequency is the tumping at? 60Hz, 6KHz? 1HZ ??? rough idea.
Let's see what the results of the above are, cuz next step will probably be grounding, with a clip lead, the + sides of C100 and C150 to absolutely eliminate any chance that some input circuitry is causing the problem. You might also try grounding the junction of R39 and R54 just for kicks.
Let's see what these tests do........
PostPosted: Dec Mon 17, 2018 5:25 pm
Both channels work and sound good. Volume, Bass and Treble work.
The volume control also controls the thump. The volume control is just at the right edge of the schematic, R200 at 50KOhms. It sounds like it's thumping at about 2 to 3 times a second.
Grounding R39 and R54 is a good idea. I bet it would keep thumping, but I'll check it when I get home.
PostPosted: Dec Tue 18, 2018 2:58 am
I grounded R39 and R54 and went through the inputs with the selector switch: AUX 1, AUX 2, and FM all had the thump sine wave in mono. Phono started with a giant thump sine wave and slowly went to zero. In stereo you can see the giant sine wave start in phono mode, then it's gone. You can just see a spike in the other modes.
There is no sign of the sine wave at the front of C100 and C150, but you can see a small sine wave after the capacitors, at the base of Q110 and Q112.
With no input, I have a voltage of 0.6 volts on one channel's input and 0.2 volts on the other. Q110 has a base voltage of 1.05 volts and Q112's base is at 0.995 volts.
PostPosted: Dec Tue 18, 2018 4:06 am
Look to the -13volt power supply. Dried out electrolytic capacitors in the power supply could lead to "motorboat" oscillation, which is what you seem to have. The electrolytic closest to the junction of R100 and R103 should be first suspect.
C101, C103, C151, and C153 are also suspect.
-Chuck
PostPosted: Dec Tue 18, 2018 4:37 am
I've replaced all electrolytic capacitors. The -13 volts is low, reading -10.8. The -15 is good and there is a 1KOhm resistor between the -15 and -13, and it's good, reading 999Ohms. Bu I don't know it -13 is correct, the output capacitors C102 and 152 are not 16uf, they are 0.22 ceramic. Let me get the voltages of those four transistors.
PostPosted: Dec Tue 18, 2018 5:13 am
Here's the voltages on the four transistors.
PostPosted: Dec Tue 18, 2018 4:29 pm
I found that adjusting the volume does very little to the sine wave, but even with the volume all the way down, if I turn the balance to the left or right the sine wave vanishes, and the bass control will vary the sine wave, even though both controls are on another board and after the volume control. I do believe both boards share the -13 volts and a ground, so I need to check that.
PostPosted: Dec Tue 18, 2018 5:31 pm
It occurs to me that a sine wave does not thump. If it's really a sine wave, you should be hearing some low frequency hum or buzz, not a thump. Thumping noises only happen with spikes (impulse noise in other words).
What is the frequency, and p-p level of this sine wave, and is it symmetrical around 0v (ground) on the scope? Photo of the scope trace might be helpful
PostPosted: Dec Tue 18, 2018 6:51 pm
Thumps may come from capacitors... Monitor the suspect power source to be sure that it is not the that, if so, replace with caps of a greater MTBF, use longer leads and heat sink when soldering. Only go to next "step" in voltage rating, for example: 16 volts to 25 volts, not only will there be a size, space issue but also there is the possibility fidelity. O.K. in the P.S. though. No need to do the entire amp, just in the suspect areas...
YMMV
Chas
PostPosted: Dec Wed 19, 2018 2:40 am
I checked the grounds at the 2 boards, they are good. The sine wave does appear on the -10.7 volts when in mono.
Here's the scope view, it's set at 50msec per division, so it has about 165msec wavelength or about 6Hz at about 0.5 volts at the record out RCAs.
PostPosted: Dec Wed 19, 2018 3:18 am
I pulled the power connector from the tone control board, and it did not affect the sine wave at the record out RCA. So the whole problem seems to be in the preamp board.
PostPosted: Dec Wed 19, 2018 5:14 am
Is the B- still low at -10.8 volts? Do any of the power supply voltages drop when the thump occurs? I recommend using an analog meter for testing, or a min/max digital meter.
PostPosted: Dec Wed 19, 2018 6:46 pm
I put the old caps back in and the thumping went away. Totally clean at the record out RCAs. Tried it several times all good. Put in the only other 10uf (the schematic says 15uf but 10uf 15v were in there) caps I had, UKW Nichicon 10uf 63 volts, I did have 50 volts in, and the thumping started back up. Put the old ones back in and clean again. So I guess I'll look for some 10uf 15 volt caps.
PostPosted: Dec Wed 19, 2018 6:54 pm
The 63v cap is not the issue. It may be BAD ... but higher voltage rating is perfectly ok to use.
Is the cap perhaps a NON POLARIZED electrolyitc? That would definitely make a difference
PostPosted: Dec Wed 19, 2018 7:42 pm
It's not polarized. The caps I got to replace the axial 10uf 15 volts were Nichicon TVX 10uf 50 volts. They couldn't be bad, because I also tried Nichicon's UKW 10uf 63 volts. I just tried it again with the old caps and it's still good. Maybe I'll just keep those 2 old caps in it.
