It is currently May Tue 26, 2020 7:32 pm
 Post subject: Anybody have a Yamaha CR-2020?
PostPosted: Apr Tue 14, 2020 11:48 pm
I need to replace the speaker terminals board on my Yamaha A-1 integrated amp. I found a board on Ebay from a Yamaha CR-2020 that might fit if the spacing for the mounting holes is the same (3 1/4"). I asked the seller to measure it, but alas, no response.
Me transmitte sursum, Caledoni! Dan B
 Post subject: Re: Anybody have a Yamaha CR-2020?
PostPosted: Apr Wed 15, 2020 3:16 am
Is that terminal threaded with a nut? If so can you just replace the broken terminal?
PostPosted: Apr Wed 15, 2020 3:25 am
The gray plastic is broken off. I'm not sure how it works. I was also thinking about replacing the unit with some 5 way binding posts.
PostPosted: Apr Wed 15, 2020 8:20 am
Where did you get that receiver? It sure doesn't look like any CR 2020 I've ever worked on; that terminal block is not the type normally used.
PostPosted: Apr Wed 15, 2020 12:19 pm
It's not a CR-2020. It's an A-1 integrated amp from 1978. Except for the colors of the little knobs, the A-1 speaker terminals looks the same as the CR-2020 speaker terminals.
PostPosted: Apr Wed 15, 2020 1:48 pm
Are you after an "authentic" replacement? If not, just cut a piece of plastic to cover the entire rectangular cutout, and replace those with regular binding posts
PostPosted: Apr Wed 15, 2020 2:21 pm
That is the Plan B if I don't find originals.
