It is currently Mar Tue 19, 2019 11:06 am
 Post subject: EV Model 870 Matching Transformer
PostPosted: Jan Wed 16, 2019 6:49 am
Does anyone have a spec sheet for an Electro-Voice Model 870 Matching Transformer?
What were these used for?
 Post subject: Re: EV Model 870 Matching Transformer
PostPosted: Jan Wed 16, 2019 9:08 pm
MODEL 870- 12-Watt Line Matching Transformer for mounting on side of
CDP Model 847. Primary taps for 12, 8, 4, 2 and 1 watts with 70 volt line.
Impedance taps for 45, 500, 2500 and 5000 ohms. Size: 2½ in. x 2½ in. x 3 in.;
Shipping Weight: 2 lbs. List Price, Model 870 . . .. . ........... .. . . . . $12.00
Info taken from page 29 of this document:
https://www.google.com/url?sa=t&rct=j&q ... YTr0vVO1-E
PostPosted: Jan Sun 20, 2019 4:45 am
5000 ohm input. Dang I wonder if you can use that as a amp output transformer. 5K to 8 ohm out.
PostPosted: Jan Sun 20, 2019 5:04 am
As long as you don't exceed the ratings, it should work fine. Transformers go both ways.
PostPosted: Jan Sun 20, 2019 5:25 pm
Unfortunately no, you cannot use a line matching transformer as a plate output transformer, for several reasons:
1) The primary winding insulation will not withstand the several hundred volts of a plate circuit.
2) If the output is push-pull, the primary would have to be center-tapped which it probably is not.
3) If the output is single-ended, the transformer core must have an air gap to prevent DC saturation, which a matching transformer does not have.
-David
