It is currently Mar Tue 19, 2019 4:33 am
 Post subject: Craig 212 tape recorder won't play or record
PostPosted: Jan Fri 25, 2019 1:59 pm
I acquired this Craig 212 Reel to Reel portable tape recorder(circa 1960's) that by outward appearances is in good shape. I replaced two belts which I expected and the transport works fine. Cleaned the volume control pot with Nu-trol. Cleaned all the mechanical/electrical switches. When in play I get a a large hiss from speaker but the funny part is that the hiss goes away when volume at max...its louder when it is set at zero. It will not record either with a tested microphone. My guess is the circuit board is cooked....or is it the volume pot? I know nothing about electrical troubleshooting even though there is a schematic on inside cover. Just curious what the forum members think.
 Post subject: Re: Craig 212 tape recorder won't play or record
PostPosted: Jan Fri 25, 2019 6:24 pm
Clean the heads and record-playback switch.
PostPosted: Jan Fri 25, 2019 8:01 pm
Heads are super clean...used isopropol alcohol, I've cleaned the switches several times electrical cleaner and still no record or playback.
PostPosted: Jan Sat 26, 2019 12:21 am
Electrolytic caps are always considered suspect in old equipment.
Before that, though, I'd have a good look at the solder joints.
PostPosted: Jan Sat 26, 2019 4:51 am
Did you try a tape made on another tape recorder?
Did you record on the Craig, and then play the tape on another tape recorder?
Did you feed a low level signal to the head terminals when on play without a tape?
Should have a schematic inside.
de
VE7ASO VE7ZSO
Steve Dow
ve7aso@rac.ca
Users browsing this forum: Poston Drake and 3 guests
