It is currently Feb Mon 24, 2020 9:49 pm
 Post subject: odd metal capacitor in Webster-Chicago Wire recorder
PostPosted: Apr Sun 14, 2019 2:44 am
C6 capacitor schematic section.doc [178 KiB]
Downloaded 16 times
I am restoring a webster-chicago wire recorder from 1956. It's in very good shape, powered up, but shorted a 1 Amp heathkit-type plug fuse when placed into run mode. I have new rectifier and 3 additional tubes for it. Basically I am replacing capacitors and resistors. These are typical paper/wax capacitors.
I have run into the pictured 0.01 MFD metal capacitor with its case grounded. It is in the microphone portion of the schematic. I am assuming this was an early attempt to shield this part of the circuit, prevent hum and/or distortion. The cap output wire is shielded in a coaxial grounding sheath as well which I was planning to retain.
Is there any reason I could not replace this with a typical polypropylene cap, (and dispense with the case grounding obviously)? Or would it be wiser to leave the capacitor unreplaced, assuming it tested ok?
 Post subject: Re: odd metal capacitor in Webster-Chicago Wire recorder
PostPosted: Apr Sun 14, 2019 2:57 am
If it tests ok, leave it in. I've not seen one fail.
Scott.
PostPosted: Apr Mon 15, 2019 3:45 pm
If one did replace it, just add a wrap of copper foil tape and ground it. I found those units to be quite difficult to service because of access to some parts, but very rewarding. Sound quality was way better than I would have thought. Lubrication and type of lube on moving parts is important.
PostPosted: Apr Tue 23, 2019 2:12 am
Thanks for the reply
What type of lubrication did you use? There is only one worm gear in there, a drive for the spool. I have used a watchmakers grease for these types of applications, it has seemed to hold up well. What do you recommend?
PostPosted: Apr Tue 30, 2019 4:46 pm
The metal piece that carries the head slides up and down. I think I used a moly grease on the contact areas of that. I remember also having to go in with a long tube to lube one of the motor bearings. I use lightweight hydraulic oil for those.
