It is currently Nov Mon 11, 2019 9:27 pm
Post New Topic Post Reply  [ 22 posts ]  Go to page Previous  1, 2
 Post subject: Re: Marantz cassette machine: need DRIVE belts
PostPosted: Mar Mon 11, 2019 8:48 pm
engineer wrote:
Tkilboy wrote:
... Also, be careful with the liquefied belts. Clean out the tar carefully with alcohol before it gets everywhere... Tim
Iso-propyl alcohol did not work. Nor did "Googone". However, "Goof off" worked very well. Yes, liquefied rubber is a potential disaster... I learned that quickly and did not make any serious handling mistakes, but it did take a day to get a couple of black marks off my hands...!
Cheers,
Roger
PS. I'm now looking into pinch-roller rubber surface conditioner... hopefully to make it grip the tape.
Acetone is the way to go when removing the liquefied belts from the drive surfaces.
Jim
KE8GMW
"AC volts and DC volts and little lamps and lities..."
PostPosted: Apr Wed 17, 2019 10:14 pm
I should close this thread formally... Problem was not the pinch roller (although I did clean and de-gloss it.) The problem was no lubrication on the front capstan bearing... found by accident; I was desperate! Two drops of thin oil on it (and the back bearing) and it is now perfect... no audible wow/flutter on even slow piano music.
I always say "You have to get lucky sometimes!"
Thanks for all the relies and comments... a good journey and "All's well that ends well!"
Cheers,
Roger
Roger Jones,
Thornhill, Ontario
