It is currently Sep Wed 30, 2020 11:09 am
 Post subject: Fisher Ambassador
PostPosted: Mar Sun 03, 2019 3:49 am
Saw this at an estate sale today for $65. Pristine cabinet, but didn't sound good and nothing coming from the right channel except a little weak distorted treble. Googled info says this is a 1965 model with a hybrid amplifier. I can work with tube circuitry, but just don't know enough about transistors and solid state circuitry if there's a problem in the amp (and a restoration topic in another forum does mention crappy transistors in this model) not to mention the enormous size and weight (it was all I could do to pull one end of it out a foot from the wall to look at the chassis). I would have to hire someone (or several someones) to move it across town to my place, plus I really have no room for it. So I reluctantly left it behind. On the other hand, if it were a top of the line President (which apparently was available in a similar, albeit slightly fancier cabinet), I could make room for that, even if I had to move the couch out into the yard....
 Post subject: Re: Fisher Ambassador
PostPosted: Mar Sun 03, 2019 3:56 am
I would've grabbed it. Those Fisher hybrids are rare and interesting
William
PostPosted: Mar Sun 03, 2019 4:05 am
My dear old Elmer, who has long since departed this world, used to refer to transistors as three legged fuses, still makes me smile to this day. :)
PostPosted: Mar Sun 03, 2019 5:11 am
He wasn't wrong, Greg--all it takes is one shorted driver transistor to take out everything in it's downwind path. I had a late 60's Fisher integrated stereo amp. Protection for the outputs? That was when it smoked...that was your cue to shut it down :wink:
William
PostPosted: Mar Sun 03, 2019 1:18 pm
+1
I had a similar speaker issue and it turned out to be a dirty control. A little DeOxit fixed it. As long as you hear something out of the speaker it's unlikely to be a transistor problem.
kb3wbb
PostPosted: Mar Sun 03, 2019 9:46 pm
I believe that one has ELL80 (6HU8) feeding the final transistor stage. Pricy tube if that ends up being the problem.
PostPosted: Mar Tue 05, 2019 10:03 pm
It is possible to make an adaptor to use 2 EL95 to replace ELL80
Brian McAllister
Sarasota FL
http://oldtech.net
PostPosted: Mar Wed 06, 2019 9:23 pm
Thanks for sharing the picture. Don't get to see too many units of that vintage.
— Arthur C. Clarke
