It is currently Nov Fri 22, 2019 5:35 am
 Post subject: Balanced Tip-Ring-Sleve Wiring
PostPosted: Mar Fri 29, 2019 12:03 am
Greetings to the Forum:
I have run into a small gap in my knowledge and I hope that someone here can provide me with the missing information.
I need to make up a patch cord for balanced audio which is XLR on one end and a tip-ring-sleeve plug on the other. (I am going from a line output XLR on one board to a line input jack on another.)
The convention for wiring XLR's seems to be:
1: shield
2: High or +
3: Low or -
The question is: what is the accepted wiring convention for a tip-ring-sleeve plug? I would assume that the shield goes to the sleeve, but what about the tip and ring? Which is + and which is - ?
Jim T.
KB6GM
 Post subject: Re: Balanced Tip-Ring-Sleve Wiring
PostPosted: Mar Fri 29, 2019 1:06 am
From Behringer: Tip=+
PostPosted: Mar Fri 29, 2019 1:09 am
Here is a drawing:
PostPosted: Mar Fri 29, 2019 1:26 am
Got It!
Thanks Guys!
Regards,
Jim T.
KB6GM
Users browsing this forum: Brett_Buck and 3 guests
