It is currently Jul Thu 18, 2019 7:40 am
 Post subject: Kenwood KR-6600 Meters dead
PostPosted: May Tue 07, 2019 2:46 pm
I have an eBay Kenwood KR-6600 receiver. Works fine. But both meters dead. They do move when current is introduced to them. Since both the signal and tuning meters are dead, I am thinking they must share a compnent or components. Visually everything looks good. Any suggestions as to where to start? Downloaded schematic but hard to read due to quality. I suspect an IC chip since the caps and resistors all look fine.
Keneye
York, PA
 Post subject: Re: Kenwood KR-6600 Meters dead
PostPosted: May Tue 07, 2019 9:12 pm
You sure it's not a KR-6600? I just sent you a PM.
PostPosted: May Tue 07, 2019 9:41 pm
Bad ground on lamp board. Bad S1 (function switch). Bad ICG1 in tuner assembly. Bad connections to any of these parts.
PostPosted: May Wed 08, 2019 5:21 pm
Thanks. Will dig into it and check.
Keneye
York, PA
PostPosted: May Thu 09, 2019 1:47 am
Grounds ok. IC chip voltages off. Ordered new IC chip. Thanks!
Keneye
York, PA
