It is currently Oct Fri 18, 2019 10:06 pm
Post New Topic Post Reply  [ 57 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: found an old Gibson Amp can't find model #
PostPosted: Jun Wed 12, 2019 2:34 pm
I may be g at the wrong two resistors in parallel as it looks like another set here
and you were right about the old stuff ,,,,,its out
and when I test the new stuff its all in ,,go figure
PostPosted: Jun Wed 12, 2019 2:52 pm
close together in the chassis doesnt necessarily mean that they are in parallel. they would need to be connected to the same point on both ends. the color code values and pin locations help to locate on the diagram.
the new film resistors should be within tolerances. yours look to be at least 1/2 watt
PostPosted: Jun Wed 12, 2019 4:41 pm
blainenbecky wrote:
tubeAMP wrote:
those NOS carbon resistors may be out of tolerance as well. check the with ohm meter. checking resistors in parallel in the amp will not give you singular reading
Roger that and thanks
is this the parallel resistors circled in red bro
the colors on the 2 resistor in the big circle are brn blk yel sil
and the other resistor is red gre yel sil
so if I am reading the color chart right this must be the 2 in question .
I am also guessing when you put the resistors side buy side like that it does the same as wiring caps together and multiply the 2 values into one right? ,,,,,so it could have just as easily have been one 350M resistor in that spot right ??
so I could just put one orange,green and black resistor there and do the same thing right ? or did they use 2 resistors to get more Watts ?
PostPosted: Jun Wed 12, 2019 5:14 pm
Nope. When you parallel two resistors, the resulting resistance is:
R = (R1 x R2) / (R1 + R2)
The parallel combination of your two resistors is 71428 ohms, which would be written 71M in the ancient notation of your schematic or 71K ohms in modern usage.
-Chuck
<edit, corrected my math, I shouldnt be allowed out without my sliderool.
PostPosted: Jun Wed 12, 2019 5:37 pm
unusual diagram using M for thousands. it is a 100K and 250K resistor in parallel. most do not use two resistors in parallel like that. may be for accuracy because there were no 71K resistors ? you need to identify the tube pins to verify connections. try this site below. type in the tube number
http://tdsl.duncanamps.com/tubesearch.php
PostPosted: Jun Wed 12, 2019 5:42 pm
Many companies were still using M=1000 in schematic diagrams and parts lists as late as 1946.
-Chuck
PostPosted: Jun Wed 12, 2019 8:17 pm
In Roman Numerals, 1000 = M. This is likely the reason. It's not really unusual. It was the standard for 1000 on schematics for many years until it changed to K (as already noted in a previous post)
I am NOT an audio expert, but this is a push-pull output and they may have paralleled those two resistors in order to properly balance the amplitudes of the opposing phases into the 6V6 outputs? .... just my guess. The 6J5 is acting as a phase inverter?
cheers
PostPosted: Jun Thu 13, 2019 1:00 am
thanks for the info guys it is a big help,,,,,,got me a dim bulb tester made today that should be a help when I get the Caps in.
PostPosted: Jun Thu 13, 2019 1:07 am
-Chuck
OK this is blowing my mind a bit ,,,,,I am going to find some vids on youtube to try and get a better grip on it ,thanks Chuck
Well,,,,,,,,,,,,,,edited as I just did some vids on it and Boy my hat is off to you guys,,link to the vid that talks about parallel resistors https://youtu.be/ZrMw7P6P2Gw
PostPosted: Jun Tue 18, 2019 4:19 pm
you could probably find a better video explaining parallel circuits
PostPosted: Jun Tue 18, 2019 8:03 pm
maybe so bro,,,,,the caps came in yesterday
so I am pretty close to starting back on the project .looking at vid now to learn how to stuff the
new caps in the old caps so it will look a little better on the inside .
PostPosted: Jun Wed 19, 2019 2:29 am
When measuring resistors in circuit you have to be careful that there is nothing in parallel. This is usually not quite as obvious as the parallel resistors you pictured earlier. A good rule of thumb is that if a resistor reads too high, you know it is bad. If it reads correct or low you cannot be sure unless you are positive that there is nothing in parallel. When not sure, lift one leg of the resistor and measure, then you know definitively.
PostPosted: Jun Mon 24, 2019 9:26 pm
found some time to attempt some Cap re stuffing.
some pics of the progress
got the 2 big Caps done .got 2 more and it will be power up time
one of the resistors one the smaller yellow caps
yellow cap after stuffing a new cap in it
after stuffing the new Caps in the old cap shells
and now to fire it up
PostPosted: Jun Tue 25, 2019 1:16 am
just fired it up and man am I happy ,,,,,here is a link to a youtube of it playing ,thanks guys for the help ,,,,,now on to
trying to get the covering glued back down and mounting it back into the box.
https://youtu.be/uVZM8WRI_kA
https://www.youtube.com/watch?v=uVZM8WRI_kA
now for some glue on this old tied covering
Image Image
Image Image
this covering is in really bad shape but I really want to keep as much of it original as I can
Image Image
Image Image
Image Image
well I got the covering glued back down and put the amp back into the cabinet and wouldn't you know it it would not power up.
so after taking it back out the cabinet I noticed the power wire had broken off the on/off switch .once I got that back in place the thing powered up and sounds really good ,,,,,so I guess I'm all done with the old girl,,it looks its age and it plays great and what could be better .thanks guys
another vid of it playing https://youtu.be/OOsDpwYlk-0
PostPosted: Jul Mon 15, 2019 9:20 pm
Nice going, glad you found that and saved it.
It looks like the back helps to hold the cabinet together when you lift it. But you won't be hauling it to parties, altho you could. 8)
Burl Ives, RIP, oldtimer.
[:l>)
PostPosted: Jul Mon 15, 2019 9:33 pm
sounds great looks good :)
PostPosted: Jul Tue 16, 2019 12:46 am
and thanks for the help with it guys .its one of the better tube amps I have had.
a lot of fun
