It is currently Feb Fri 21, 2020 12:27 pm
 Post subject: attaching test lead to printed circuit board tube socket pin
PostPosted: Jul Sun 14, 2019 4:14 am
i have motorola am receiver that has a pcb connecting all the wires to tubes and components.
alignment with signal gen says to connect hi lead to pin 7 of converter tube, but tube socket is soldered to pcb ,no terminal on pcb.
what is the practical way that this is done.
i don't think i can get an alligator clip to hold on the pcb.
thanks
john
 Post subject: Re: attaching test lead to printed circuit board tube socket
PostPosted: Jul Sun 14, 2019 4:17 am
Make your own test terminal, by soldering a short lead to the pin 7 PCB landing or socket pin, on the upper side of the board.
PostPosted: Jul Sun 14, 2019 12:42 pm
thanks
i will do that
john
PostPosted: Jul Sun 14, 2019 4:59 pm
The classic approach is to use a test socket adapter.
PostPosted: Jul Sun 14, 2019 5:50 pm
I agree with the test socket adapter except in the case of an oscillator or converter tube, in which case I would take Fifties approach.
PostPosted: Jul Mon 15, 2019 12:29 pm
Be very carefull applying heat to those early PCB boards. There is a tendency for the traces to fall off when heated. Personally I would use a test adaptor.
kb3wbb
