It is currently Oct Wed 23, 2019 11:08 am
 Post subject: DAYTON SA1000 sub woofer power amplifier
PostPosted: May Thu 23, 2019 2:48 pm
Perhaps someone can provide a lead on obtaining a schematic on this audio unit.
Its not quite vintage, but getting docs to help my son with a repair appears difficult.
Thanks for any assistance, Alan
 Post subject: Re: DAYTON SA1000 sub woofer power amplifier
PostPosted: May Fri 24, 2019 12:38 am
I believe Dayton audio is a house brand of Parts Express. Have you tried contacting them?
https://www.parts-express.com/dayton-au ... e--300-811
PostPosted: May Fri 24, 2019 10:32 am
Thanks... I will try them and let you know if any success,
PostPosted: May Tue 28, 2019 3:30 pm
No joy on getting a schematic for aid in troubleshooting this gear. It is not available and will not be released. I expect the design is considered TOP SECRET.
However, if any one knows different, I would be happy to hear otherwise. In the meantime, I am going to dive in, one element at a time.
PostPosted: May Tue 28, 2019 4:52 pm
Main issue blowing 10 A primary FUSE. All lines to the power supply card that are easily disconnected are pulled. A measure of the primary line to neutral resistance is about 1.2 ohms. That may be reasonable for a 1 kW toroid power xmfr. The model number on the xmfr is RM 1000. There is no manufacture name that I can see. There appear to be some line protection MOV's or safety caps. At least 6 in total, 2 pairs of three across the line, perhaps? I'll see if I can post a pix. Alan
PostPosted: May Tue 28, 2019 9:22 pm
DC Measurements of the transformer winding appear reasonable. It might be worthwhile to measure the AC R at 60 Hz. Would be nice to have a xmfr spec. My target now would be the line filter caps and what appears to be a common mode inductor also bridging the AC line. Looks like they use a custom made discrete AC line filter consisting of just a half a dozen parts, L and C.
PostPosted: May Wed 29, 2019 4:04 pm
The problem with the unit is power transformer shorted primary winding. Measured Z at 60 Hz is pure real ~ 8 ohms. Now off to find the bad winding or a replacement. Units is a nice toroid wound rated at 1kVA I expect.
