It is currently May Fri 29, 2020 8:44 am
 Post subject: Dynaco ST-70 Clone (Pictured)
PostPosted: Jun Fri 14, 2019 7:38 pm
Does anyone recognize this ST-70 Clone Manufacturer, etc.?
TIA,
Terry
 Post subject: Re: Dynaco ST-70 Clone (Pictured)
PostPosted: Jun Fri 14, 2019 9:37 pm
Well it has a PA60 power transfomer , so most likely someone just chromed the end bells of the power transfomers and made their own faceplate for the run of the mill ST 70 .They also added a extra filter cap , did away with the 5AR4 and added AC ballance pots so the EL34s won't have to be matched .
Can you read the number on the output transformers ( A470 ) ? , that will tell you for sure what it is .
Mark
PostPosted: Jun Fri 14, 2019 10:13 pm
What do you suppose that DIN connector is for?
PostPosted: Jun Fri 14, 2019 10:25 pm
Power for a preamp , they did away with the octal sockets on the font . Trace them back to see if B+ and filament voltages go to the pins .
Mark
PostPosted: Jun Sun 16, 2019 12:04 am
No numbers on those transformers...
PostPosted: Jun Sun 16, 2019 5:33 am
It looks a lot like a mostly stock design with a replacement fiberglass PWB and a diode rectifier "can". I don't recognize the chassis design. I assume the DIN connector goes to the bias check terminals that would otherwise have been routed to the missing sockets on the front, but it is not clear from the pictures. There are two additional potentiometers, which may be for setting the bias individually on each side.
Brett
p.s. now I get it, it's a stock or stock-like chassis with a blanking panel across the front. The output transformers look stock to me, the power transformer may be the Triode unit, all are chromed, of course, instead of painted flat black.
Users browsing this forum: Brett_Buck and 8 guests
