It is currently Oct Tue 26, 2021 5:51 am
 Post subject: Looking For Sam's 540-8 From 1961 For Bell 2425 Receiver
PostPosted: Aug Mon 09, 2021 9:17 pm
Got a 1961 Bell Sounds Receiver in the shop today...Model 2425. Lots of output hum and no cathode voltage (unless they are running it to chassis thru 12AX7 heater...see next comment). I started looking at that circuit and looks like they are doing something funky there...running the four 6V6 cathodes to a electrolytic can (normal) and to the heater pin 5 of a 12AX7..??? That's a new one to me. I found a schematic of a 2420, but that is different than the 2425 which has 2 rectifier tubes---EZ80 and EZ81, and numerous other differences..I would like to see the 2425 schematic, from Sam's 540-8 if someone has it available. Thanks in advance!
 Post subject: Re: Looking For Sam's 540-8 From 1961 For Bell 2425 Receiver
PostPosted: Aug Tue 10, 2021 3:24 am
Bell 2425
PostPosted: Aug Tue 10, 2021 5:31 am
Interesting...Never saw this type of output tube cathode circuit driving the heaters of the two12AX7's (V-9/V10)---if I'm reading it right.????
PostPosted: Aug Tue 10, 2021 12:19 pm
I think if you can look at the power transformer side of the schematic somehow, you'll see a fliament winding with an arrow to "V" , which goes to the filaments in the 12AX7s. It's just drawn rather oddly, and it is a bit of an odd duck circuit as well. I don't recall seeing that configuration either.
PostPosted: Aug Tue 10, 2021 2:49 pm
A member here sent a copy of that Sam's folder....Found 2 bad 6V6's/replaced...and the odd cathode bias circuit is working now......Thanks!
PostPosted: Aug Wed 11, 2021 4:49 pm
DC heaters for the phono preamp and no need for a big cathode resistor. 20V is less than the nominal but that results in lower noise.
PostPosted: Aug Thu 12, 2021 2:32 pm
OK...Now it makes sense...Clever design.
