It is currently Jan Fri 21, 2022 3:30 pm
 Post subject: Ampeg J-12D
PostPosted: Sep Thu 02, 2021 4:31 pm
Does anyone have any information on this amp.. I replaced all caps .. when i turn it on... no mic connected its quite .. no hum.. but when i plug in a mic i get a load hum when i turn up the volume its a metal case mic as soon as i touch the mic the hum comes.. any clue on why? grounding ??
Skip
 Post subject: Re: Ampeg J-12D
PostPosted: Sep Thu 02, 2021 6:52 pm
Try another mike, or fix the ground on the one you have...
PostPosted: Sep Thu 02, 2021 7:05 pm
+1 to that. Or clean the mic connector on the amp and on the mic. And check to make sure its the correct mic connector....if it's supposed to be a 3 conductor, and you're using one with two, or even visa versa, that could easily be the problem.
