It is currently Jan Fri 28, 2022 6:28 pm
 Post subject: HeathKit UA-1 Voltage Feedback Loop Off 16 Ohm Tap
PostPosted: Sep Wed 22, 2021 8:02 pm
Hello to all. The loop puts 18db back to V1A cathode. The manual says to open the loop for troubleshooting with 1Kh and .09 VRMS at the input and a 16 ohm dummy load. My question is, should I be seeing signal voltage increases at all the signal grids(including EL84’s) if I don’t open the feedback loop? Thanks for any help. Al
Why is there never enough time to do it right the first time…
But always time to do it over…
 Post subject: Re: HealthKit UA-1 Voltage Feedback Loop Off 16 Ohm Tap
PostPosted: Sep Wed 22, 2021 8:56 pm
File comment: Click on image to enlarge
 Post subject: Re: HeathKit UA-1 Voltage Feedback Loop Off 16 Ohm Tap
PostPosted: Sep Thu 23, 2021 8:28 pm
The feedback is to the first stage; so its gain is reduced. The remaining stages will have the same levels as when it's running with feedback, though the input level will be much lower. Without feedback, first stage will have a gain of 100 or more, phase inverter has a gain of 1, (and -1 on the second output). So the first stage provides all the gain to the EL84 grids.
PostPosted: Sep Fri 24, 2021 2:32 am
Thanks much Tom. Great explanation. I built these a while back and am just now walking through them with a scope and generator. Al
