It is currently Dec Sun 05, 2021 9:21 am
 Post subject: FM Stuck?
PostPosted: Oct Sun 03, 2021 8:41 pm
Hello,
I have an Airline solid state stereo console and the FM is stuck in one band. The dial moves all the way through the bands and I can see the AM fins moving but just getting bad FM reception on one station only throughout the range.....is there a probable cause for this?
Thank you!
 Post subject: Re: FM Stuck?
PostPosted: Oct Mon 04, 2021 2:22 pm
The cable/string for your FM band tuner is broke or loose.
PostPosted: Oct Mon 04, 2021 3:37 pm
First, see if there is a separate tuning unit for the FM band. If so, the advice to check the dial cord is spot on; both tuning capacitors must turn together when the tuning knob is operated. If both the AM and FM bands are tuned by the same tuning capacitor assembly (the most common method), then you have a problem with the FM oscillator circuit; a broken connection to the tuning capacitor or coil, or a bad oscillator transistor.
PostPosted: Oct Mon 04, 2021 5:11 pm
Thanks Tim, the AM tunes nicely and is connected to the same FM assembly, so I believe it's a bad oscillator.....will check further.
Thanks!
PostPosted: Oct Wed 06, 2021 12:09 am
Thanks!
If the FM tuning cap rotates and is driven correctly by the tuning knob then the local oscillator is very likely dead (or locked to a fixed frequency). You may also try to adjust the L.O trimmer cap (usually mounted on the top of the tuning cap frame, but not allways) to see if it has any effect on the received channel.
Of course since we don't have the type and schematic of your receiver we can only suppose it use a standard V.C tuning in the FM band and not the Varicap diode (DC voltage tuning) system. A Varicap tuning uses a potentiometer coupled to the tuning assembly to generate the tuning voltage. Could you confirm which type it is ?
