It is currently Jan Tue 18, 2022 9:36 pm
 Post subject: What substitute for miniature 40 volt DC incandescent bulb
PostPosted: Nov Wed 24, 2021 4:03 am
The bulb in question is the pilot or "on" light for an early 1970's Realistic 4 channel integrated amp....a QA-680.
Attached is a photo of said bulb.
Power to the bulb is the 40 volt DC rail voltage. My experience is not vast and I have not encountered a miniature panel lamp bulb needing a voltage that high. 6.3 volts, 8 volts and 12 volts comprise all of the spares I've managed to accumulate.
Browsing part vendor's websites makes me think prospects of finding a direct replacement are slim and none.
Can an LED be adapted to work with 40 volts DC? And if so, how?
Thanks in a advance to any who choose to respond.
 Post subject: Re: What substitute for miniature 40 volt DC incandescent bu
PostPosted: Nov Wed 24, 2021 5:06 am
This lamp would work with a dropping resistor , so would an led with a large enough dropping resistor .
https://www.galco.com/buy/Chicago-Miniature/327
About 300 ohm 1 watt resistor
https://www.goldmine-elec-products.com/ ... ber=G25735
1 k ohm 2 watt resistor
Mark
PG-18-23909
PostPosted: Nov Wed 24, 2021 5:32 am
Are you certain that the lamp is connected directly across the 40V power rail without a series resistor? That would be very unusual.
If the lamp is open, and there is a series resistor, and you are making the voltage measurement with a high impedance meter such as a DVM, there will be no voltage drop for you to measure so your meter will indicate the full supply voltage.
PostPosted: Nov Wed 24, 2021 6:21 am
That had me (try) taking a closer look. I cannot manipulate the power supply much at present.
There is a resistor present on that board and looks to be associated with the pins to which the lamp bulb is connected. It is 470 ohms and I believe 1 watt.
PostPosted: Nov Wed 24, 2021 1:20 pm
If that 470 ohm resistor is indeed in series with the lamp, it was probably a 9-12v lamp, depending on the lamps' current rating.
PostPosted: Nov Thu 25, 2021 5:22 am
Since I have on hand a couple of different 12 volt bulbs with leads but of different milliamperes, I measured voltages with bulbs connected. Voltages differed and neither produced a 12 volt reading.
But a 5mm green LED I have with a 4.7K ohm resistor looks like it will do nicely. Not overly bright but bright enough.
My sincerest thanks to the members who took the time to reply.
