Page 1 of 1
[ 9 posts ] |
Author |
Tbirdkid
Post subject: Odd Phono Ceramic Cartridge Circuit--Need Opinions/Thoughts Posted: May Sun 15, 2022 7:31 pm |
Joined: Aug Sun 23, 2015 5:01 pm Posts: 1387 Location: NJ 08090
Customer brought in a 1966 Packard Bell stereo console....Model RPC72W...solid state. The phono circuit has me stumped. I put in a new ceramic cartridge to replace the old one....but I just get weak tiny sound. I tried a couple other cartridges, no change. I found I got 15vdc on the hot tip of the RCA jacks from the phono cable. Looking at the schematic I now see there is voltage applied to each side (L-gets 7v to the outside RCA plug/R-gets 7v to the tip thru a 2.2k resistor). Never saw this before...can't understand what they were doing. I'm guessing that voltage is killing my signal from the cartridge. See attached circuit....
Top |
jimtech
Post subject: Re: Odd Phono Ceramic Cartridge Circuit--Need Opinions/Thoug Posted: May Sun 15, 2022 7:56 pm |
Member |
Joined: Nov Sun 29, 2020 4:59 pm Posts: 544 Location: Northeast Illinois
That's not the usual schematic symbol for a ceramic phono cartridge, and not something that I've ever encountered. A phono pickup that produces a variable resistance? Your schematic looks to be from a Sams Photofact. What does the parts list say about the original cartridge?
- Jim
Top |
Mr. Detrola
Post subject: Re: Odd Phono Ceramic Cartridge Circuit--Need Opinions/Thoug Posted: May Sun 15, 2022 8:04 pm |
I agree it's likely that was a very special cartridge which required that applied voltage to work properly. Possibly along the lines of the old ultrasonic TV remote receivers that had a + voltage applied to the center pin of the RCA jack and wouldn't work if that voltage was not present at the microphone.
_________________ Dennis
Top |
jimtech
Post subject: Re: Odd Phono Ceramic Cartridge Circuit--Need Opinions/Thoug Posted: May Sun 15, 2022 8:23 pm |
Member |
To use a "normal" ceramic cartridge, I'd start by removing the 2200 ohm resistors R83 and R128 and the +7V connection to the left RCA jack. Instead connect the jack shell to ground like the right channel. Some additional tweeks may be necessary, as the output level (and perhaps the frequency response) of the new cartridge may be different than the original.
Also... If the original cartridge appears to be intact and functional, I notice that turntableneedles.com still has a replacement stylus available for it.
- Jim
Top |
battradio@
Post subject: Re: Odd Phono Ceramic Cartridge Circuit--Need Opinions/Thoug Posted: May Sun 15, 2022 9:52 pm |
Member |
It is Condenser phono cartridge like a condenser mic , it was made by Panasonic or Sony .It has a high level output and a special EQ and will need a different preamp stage to make it sound correct with a different cartridge .
_________________ Mark (Conti the brain damaged robot ) PG-18-23909
Top |
Tbirdkid
Post subject: Re: Odd Phono Ceramic Cartridge Circuit--Need Opinions/Thoug Posted: May Mon 16, 2022 2:08 am |
Thanks for the info guys!!....I went back and checked the old cartridge and got good ohm readings out of each channel..but the needle is busted. I just 'assumed' it was a ceramic that was old and dead..so much for assuming. If I brush the cartridge saddle with my finger I do get some sound...so it appears alive. I ordered a needleBTW...It has a Euphonics U15-2 cartridge.
Top |
w3jn
Post subject: Re: Odd Phono Ceramic Cartridge Circuit--Need Opinions/Thoug Posted: May Mon 16, 2022 2:36 am |
Joined: Jan Thu 01, 1970 12:00 am Posts: 2443 Location: Mt. Airy, Maryland
Not a condensor, it's solid state and needs the bias.
Top |
orthophonic
Post subject: Re: Odd Phono Ceramic Cartridge Circuit--Need Opinions/Thoug Posted: May Mon 16, 2022 8:35 pm |
Joined: Sep Thu 20, 2007 2:16 am Posts: 1102 Location: Winter Park, Florida
The top line Admiral consoles used the Euphonics Miniconic also.
Top |
Tim Tress
Post subject: Re: Odd Phono Ceramic Cartridge Circuit--Need Opinions/Thoug Posted: May Fri 20, 2022 2:56 pm |
Member |
Joined: Jan Thu 01, 1970 12:00 am Posts: 11783 Location: Beaver Falls, PA. USA
Admiral used a variable resistance cartridge back in the 1940s; the element was made of conductive rubber.
_________________ Tim KA3JRT
Top |
Page 1 of 1
[ 9 posts ] |
Who is online |
Users browsing this forum: No registered users and 4 guests |
