It is currently Jun Tue 25, 2019 9:31 am
 Post subject: Amplifiers
PostPosted: Sep Sat 30, 2006 11:17 pm
What type of amplifiers do the tube radios from the 50's use?
PostPosted: Sep Sat 30, 2006 11:28 pm
Are you talking table radios, AA5 or large radios? May of them used 50C5, 50L6, 6AQ5, 6BQ5, 6V6 etc. operating as Class A. Is that what you are looking for?
PostPosted: Oct Sun 01, 2006 12:03 am
I am thinking table radios like Grundigs, Telefunkens and such. How about a Grundig 5088, for instance.
PostPosted: Oct Sun 01, 2006 12:52 am
Most German table radios used single-ended 6BQ5/EL84s. The 5088 used push-pull EL95s for a bit more power output than most...
PostPosted: Oct Sun 01, 2006 2:08 am
Isn't a push-pull amp a class AB and not class A?
PostPosted: Oct Sun 01, 2006 2:13 am
Probably is. In the post above, I was referring to single-ended radios...
PostPosted: Oct Sun 01, 2006 2:39 am
If I see that a vintage radio of the types I described has two amplifier tubes ( say two El95s) should that clue me in that it is Push-pull? I'm asking because I've read that Class A amps are supposed have a purer tone.
PostPosted: Oct Sun 01, 2006 4:03 am
If there are two output tubes, it's push-pull, or stereo (OK, parallel tubes are possible, but unlikley). Push-pull stages can be run in class A, AB or B, but single ended stages can only be run class A. Most radios using push-pull will be class A.
What defines class AB is that the output tubes are cut off for part of the AC cycle. This usually requires a separate bias supply, not cathode bias.
PostPosted: Oct Sun 01, 2006 4:37 am
What is a typical new stereo like an NAD, Class A, AB or B?
PostPosted: Oct Mon 02, 2006 1:31 am
With the boutique operating classes available today, you'd just about have to consult the mfg. specs.
-Ed
PostPosted: Oct Mon 02, 2006 4:36 am
Years ago I ran across a German stereo set that used IIRC an ECCLL800, it's a triode and a pair of power pentodes in a tall 9 pin configuration. This gave you push-pull output's and the phase inverter in one envelope. The set had one that was bad and I couldn't find a replacement so I made one using a couple of 6AQ5's and a 6C4 and wired it up on a 9 pin plug. The set worked fine and the customer was happy
However beautiful the strategy, you should occasionally look at the results.
Winston Churchill
