It is currently Jun Mon 17, 2019 12:25 am
 Post subject: Akai GXC-730D help needed
PostPosted: Oct Sat 07, 2006 5:16 am
If anyone knows Theres a part on the power board that looks like a transistor with a heat sink that burned up , it has the following part number on it D361 and below that it says 81E1 , is this a transistor ? anyone know what replacement is used ?
PostPosted: Oct Sat 07, 2006 8:41 am
It's probably a 2SD361, which crosses to a NTE152. This is a tab type transistor--plastic square case with a metal mounting tab on the top.
PostPosted: Oct Sun 08, 2006 5:18 am
Thanks i found the same thing doing a search with that part number and it sounds right so i will order one and try it , interesting how a deck this old is a great sounding one , it can compete with current decks in the frequency response area .
PostPosted: Oct Sun 08, 2006 5:21 am
You might want to replace the caps and check the resistors in that thing, something caused the transistor to go.
PostPosted: Oct Tue 10, 2006 4:49 pm
turns out the transistor is ok what happened was one of the direction lights shorted and it caused a burn out in a section connected to that transistor so its working now that its been repaired
mike
