It is currently Jul Thu 18, 2019 10:31 am
 Post subject: Zenith chassis 5B2 amp
PostPosted: Oct Sun 15, 2006 2:59 am
Just picked this up & can't find anything on it. Pretty sure it say 5B2 chassis. Hard to read. Supposedly 85 watts with the following tubes: 5Y3, 6BQ5, 6BQ5, 12AU7, 6AT6. Also, made into the power cord is a third wire with an RCA plug. What is this plug for?
PostPosted: Oct Sun 15, 2006 3:43 pm
I find chassis 5B20 through 5B29 covered in six Sams folders in the 440-460 range - 1959.
PostPosted: Oct Sun 15, 2006 4:44 pm
It would be an amp from a console phono and or radio combo. The rca plug is the audio input. The 85 watts is the input power, the audio out put would be around 8 to 10 watts.
PostPosted: Oct Sun 15, 2006 5:48 pm
If the power plug is a 2 pin, then the third wire is probably used as an antenna for the radio chassis that was used with this amp chassis.
Brian McAllister
Sarasota FL
http://oldtech.net
PostPosted: Oct Mon 16, 2006 2:21 am
Brian, I'm thinking like you. It has an RCA jack for the input. This plug must be for an antenna.
PostPosted: Oct Tue 17, 2006 2:18 am
Chassis 5B22, also 5B24 has those tubes - both in Beitmnans 1959, but that site isn't responding right now... The latter number has the input cable run with the power cord, so that looks like it.
PostPosted: Oct Tue 17, 2006 3:12 am
Right you are, Tom. It's a 5B24. I got this amp, working, with a 12 in speaker & a 5 inch speaker. Have no idea what I'll do with it. I had never seen an input cable molded to a 25 foot long power cord before. So, what is the RCA socket on the chassis for?
PostPosted: Oct Wed 18, 2006 4:08 pm
Was this unit possibly originally sold as an add-on stereo amplifier/speaker for an existing mono console unit? That would explain the strange power cord configuration.
PostPosted: Oct Wed 18, 2006 5:13 pm
OK, I got it figured out. The RCA socket on the chassis is for the other channel. It's a stereo amp, but I only got speakers for one side. The schematic shows speakers plugged into the RCA jack for the other side.
PostPosted: Oct Wed 18, 2006 5:52 pm
After looking at the schematic this is a mono amp, not stereo.
