It is currently Jun Mon 17, 2019 12:06 am
 Post subject: Thordarson T20W15L amplifier
PostPosted: Oct Sun 22, 2006 8:23 am
can anyone tall me about these, other than the tube lineup
PostPosted: Oct Mon 23, 2006 1:50 am
Hi,
Perhaps you did not see my reply to your post about this amp on the Nostalgia Air Forum?
I have copies of the schematics, technical data, construction drawings, and parts lists for 2 sllghtly different T-20W15 Thordarson amps as mentioned on the other forum. They are yours for the postage required to send them.
Quote: I found a Thordarson T20W15 (no "L") in Riders 1948 PA manual, Thordarson pages 1 thru 4. This amp uses 2-6V6G, 2-6J7, a 6C5, and 5Z3 rectifier. This amp uses the following transformers and chokes:
Power trans. T40675
Output trans. T40677
Driver trans. T-40647
1st. choke. T-40676
2nd. choke. T-40649
In Thordarson's Amplifier Guide 346-D, copyright 1941, there is a very similar amplifier, titled only as "15 Watt Amplifier". This amplifier uses the same tubes, but different number transformers and chokes:
Power trans. T-15R06 or T-70R62 (first number is potted type)
Output trans. T-15S90 or T-17811
Driver trans. T-15A74
1st. choke T-15C54
2nd. choke T-67C46
I can send you a copy of the information in both books; just need your mailing address. Send me an email." Unquote.
Meade
