It is currently Sep Sun 15, 2019 5:18 pm
 Post subject: Heater To Cathode Voltage
PostPosted: Oct Wed 25, 2006 10:59 pm
Out of curiousity I would love to know when heater to cathode voltage becomes a serious design consideration-only when creating cathode-follwers and split-load inverters? Is it only an issue when grounding the center tap of the filament winding to common negative?
PostPosted: Oct Wed 25, 2006 11:11 pm
One of the most important cases, of course, is rectifiers, where you can end up with hundreds of volts between heater and cathode.
Tom K6VL
PostPosted: Oct Thu 26, 2006 1:36 am
Yes, and if the tube in question has its own heater winding, you can return the center tap to the midpoint of a voltage divider.
Part of the problem is the voltage rating of the cathode insulation, but part is thermionic emission from the heater to the cathode (the cathode acts as a plate since it is positive with respect to the heater). This can inject hum into the cathode circuit.
