It is currently Mar Mon 30, 2020 2:16 pm
 Post subject: Question On Gibson EH-185 Guitar Amplifier
PostPosted: Nov Sat 18, 2006 5:59 am
Hi all I've been working on getting this amp back to life again.
I have a question as the a .00075mfd cap in the shown schematic.
What is its fuction in the circuit? If I used a 00025mfd or 001mfd what would be the differance I don't have a .00075mfd at the moment.
Also there is a 10uf cap before the 100K resisitor going to the 1 meg pot.
If the cap was 20uf would it change the tone of the amp, if so what other 10uf caps would change the tone in their locations.
thanks for any advise.
I ask these questions on the 10uf caps because the ones that were there were 40uf and 20uf yet the schematic calls for the shown 10uf caps.
Also is there a sub tube for the 6SQ7 tube that I can use, would a 6SN7 work just for testing
regards
jim
http://www.harpamps.com/gibson/pg_0030.jpg
 Post subject: Re: Question On Gibson EH-185 Guitar Amplifier
PostPosted: Nov Sat 18, 2006 2:21 pm
It's for frequency shaping. Probably to keep the amplifier from oscillating. You can use .001mfd.
It might, but not much. It's to decouple the plate supply between the various stages.
Then someone was in there before you. You can use 20uF.
regards
jim
No, it's a totally different tube. I'm surprised they used it, actually, since it has a twin diode in it too for use as a detector/amplifier in radio sets.
PostPosted: Nov Sat 18, 2006 4:16 pm
Thanks Tom for the info, and the fast reply.
would 40uf be too high for the 5AU4 rec tube?
Could I use a 12SQ7 tube just for testing as shown they used 6SQ7 peramp tubes
jim
PostPosted: Nov Sun 19, 2006 2:29 pm
40uF is fine. That would be the max size, by the way.
jim
No, because then you would have to rewire the socket. Just get the right tube.
PostPosted: Nov Sun 19, 2006 7:56 pm
Thanks Tom for the advise
Jim
