It is currently Jul Fri 30, 2021 12:43 pm
 Post subject: WTB: Clear plastic Tubing (for the leads of resisters )
PostPosted: Jun Tue 08, 2021 9:45 pm
I am looking to buy some clear plastic tubing to use to cove r the leads of Resisters and caps. Or a place where I can buy some. Also what size is best?
 Post subject: Re: WTB: Clear plastic Tubing (for the leads of resisters )
PostPosted: Jun Tue 08, 2021 9:48 pm
PM sent.
PostPosted: Jun Wed 09, 2021 12:28 am
1/16" PVC, Rubber, or Shrink wrap
https://www.amazon.com/Cole-Parmer-Flex ... NrPXRydWU=
https://www.amazon.com/16-Heat-Shrink-T ... =1-21&th=1
https://www.amazon.com/Feelers-%EF%BC%8 ... ial&sr=1-4
Andrew
PostPosted: Jun Wed 09, 2021 12:31 am
What you are looking for is called sleeving.
PostPosted: Jun Wed 09, 2021 2:10 am
Suggest teflon sleeve tubing for this. You want a size that fits easily over the leads.
PostPosted: Jun Wed 09, 2021 3:03 am
Also called Spaghetti by some techs...
Need capacitors, resistors and other parts--> http://www.tuberadios.com/capacitors
PostPosted: Jun Wed 09, 2021 5:55 am
Maybe he is thinking of the clear plastic tubing they used on transistor radios.
Andrew
PostPosted: Jun Sun 13, 2021 12:56 am
Still Looking
PostPosted: Jun Sun 13, 2021 2:30 am
How much do you need? I have a stash of eight 9-inch pieces.
PostPosted: Jun Sun 13, 2021 10:57 am
Have you used it on Capacitors?
PostPosted: Jun Sun 13, 2021 4:08 pm
I have opaque Teflon tubing if that will work .
PostPosted: Jun Mon 14, 2021 1:09 am
No, I haven't used it. I use heat shrink tubing for my restorations. This clear tubing is someting I had in my electronic supply stash for 40 years, origination unknown.
PostPosted: Jun Mon 14, 2021 3:13 am
Lets try it, how much you want for it?
PostPosted: Jun Mon 14, 2021 4:56 pm
Do you need all eight pieces?
PostPosted: Jun Mon 14, 2021 5:55 pm
Sure
PostPosted: Jun Mon 14, 2021 6:29 pm
https://www.aircraftspruce.com/catalog/ ... tubing.php
Andrew
PostPosted: Jun Mon 14, 2021 7:57 pm
You'll find all manner of things that will work---clear tubing, "shrink-fit". etc.
The so-called "spaghetti" from the old days now comes in many colors
My current brute-force answer is to stock shrink-fit in a wide variety of sizes
Post New Topic Post Reply  [ 17 posts ]  Moderators: Alan Voorhees, Philco Fan
Users browsing this forum: Barry H Bennett, clytle374 and 36 guests
