It is currently Dec Mon 06, 2021 1:22 am
 Post subject: FS: Carter Duovolt Genemotor $100 INC SHIPPING USA
PostPosted: Nov Mon 22, 2021 11:22 am
$100USD INC SHIPPING USA
I've had it for years and know nothing about it. Cleaning out the shop.
Code 6825VBNS
DC IN 5.7V 47A
DC IN 11.4 24A
DC OUT 685V .263A
File comment: MFG TAG
 Post subject: Re: FS: Carter Duovolt Genemotor $100 INC SHIPPING USA
PostPosted: Nov Thu 25, 2021 4:32 pm
I think that this motor/generator is for car radios or battery sets pre vibrator days to provide the B+ voltages. Probably from mid 1930’s.
Really neat, but I would pack the bearings with new grease before using it. Don’t use wheel bearing grease- but use a high quality synthetic high speed grease. Do not remove, replacenor move the bearings. These were high quality, very precisely line bored so that the motor could spin up fast.
PostPosted: Nov Thu 25, 2021 5:15 pm
Aircraft dynamotor. They're fitted to transmitting apparatus to power the tube plates/screens. This one would handily run a pair of 2E26 or 6146 tubes set up as a series (AM) modulator for the aircraft bands. Great little goody for experimenting with transmitters and audio amps you might want to run off 12VDC.
PostPosted: Nov Thu 25, 2021 6:22 pm
Aircraft dynamotor.
I thought aircraft systems were 28 VDC?
Since this one is also rated for 6V battery operation, I doubt it was aircraft.
PostPosted: Nov Fri 26, 2021 1:49 am
My bad. Yes, more likely for a ground transport vehicle like a Jeep or 2x6.
PostPosted: Nov Fri 26, 2021 5:52 pm
Is this a raw dynamotor, or does it have an attached can with noise supression components?
I/O connections?
I come from a long line of domesticated cryptids.
PostPosted: Nov Fri 26, 2021 6:27 pm
"I thought aircraft systems were 28 VDC?"
Aircraft dynamotors were 12-14VDC and 24-28VD. The switch to 24-28VDC electrical systems became prevalent during WWII.
KE5YTV
PostPosted: Nov Mon 29, 2021 9:31 am
I/O connections?
4 wies one end and 2 on the other. othing else except the mounting plate.
Post New Topic Post Reply  [ 8 posts ]  Moderators: Alan Voorhees, Philco Fan
Users browsing this forum: fvan, jpenn and 27 guests
