SHIPPING now available, or you can pick up at 43074, or any ESTES auction in Medina with prior arrangement. Or I will take to FedEx or PostNet here, and you can deal directly with them on packing and shipping. All prices are subject to OBO on multi unit discounts
I tested a single basic tube to verify basic functions. Unless noted, all testers have functioning LINE ADJUST, Shorts, and Gm or Emission , although adjustment and calibration is expected to be needed. NO FURTHER TESTING was done. Cosmetics are as you see them, and as partially described for each tester.
TT11 - Jackson 648. Works. Button plastic has deteriorated but fully functional. $95
TT13 - Eico 625. Works, no cover for case. $70
TT14 - Eico 625. Works, top of case very rusty $55. Combine with above for $105
TT15 - Eico 625. Works, needs new wires for plate/grid cap. Caps are included. Missing #5 knob $50 Combine with above for $80
TT19 - Superior TV-10. Works. Meter glass missing. $35
TT20 - Superior TV-11. Meter is bad. $15. Combine with above for $40 for both
TT21 - Hickok 510x/30x/50x. Needs restoration. Untested. Meter appears OK. No #83 tube. $45
TT22 - Hickok AC49. Untested. Museum piece, very old. $80
SALE PENDINGTT23 - B&K700. For parts. No tubes, no case cover. Meter has no plastic cover, needle slightly bent at the end. Deflects to full scale when flashed with an ohmmeter a few times. Yes I know how to not burn it out. So the meter "appears" to be ok. NO GUARANTEES, no further testing done. $25
File comment: JACKSON 648
File comment: EICO 625 - all three
File comment: SUPERIOR TV-10, TV-11
File comment: HICKOK 510X
File comment: HICKOK AC49
