It is currently Dec Mon 09, 2019 1:21 am
 Post subject: FOUND WTB Power Transformer for Magnavox console amp
PostPosted: Feb Sun 04, 2018 6:55 am
I need to replace the power transformer in a Magnavox amplifier 93003-00. It is a stereo push-pull EL84 circuit. The schematic is attached and some pictures of the defective one are shown. The schematic shows the screen voltage to be 300. What other info do I need to find a suitable replacement?
9303.pdf [129.56 KiB]
Downloaded 23 times
 Post subject: Re: WTB Power Transformer for Magnavox console amp
PostPosted: Feb Sun 04, 2018 5:25 pm
300195-1 (Magnavox Power Transformer) specifications.
:) Greg.
Edit: image updated.
PostPosted: Feb Sun 04, 2018 5:44 pm
Thanks so much Greg! That is exactly the part I need. Anybody have one for sale?
Are there other products that might have a similar transformer?
PostPosted: Feb Sun 04, 2018 6:05 pm
At times this Magnavox transformer 300195-1 is shown in Sams with a...
600VCT rating of .130A
PostPosted: Feb Sun 04, 2018 6:40 pm
Thanks Greg. Do you know if the Magnavox 8800 (8802) series amp also used this power transformer? Do you have access to that Sams?
PostPosted: Feb Sun 04, 2018 11:26 pm
Hi Rip ,
I have a vertical mount power transfomer that will work fine for $25 + $14 for shipping , or i have a exact power transfomer in a magnavox 9302 amp that i'm working on that will sell for $45 + $14 shipping . I will put the vertical mount in mine if you want the original transfomer .
Be sure you check the hum balance pot , i have found them shorted and have taken out the power transfomers in two diferent magnavox amps . I have spare output transfomers for you amp if you need them , have seen several open before when the power transfomer burned up .
The magnavox 8802 , transfomer doesn't 5 volt winding for the 5U4
Mark
Mark
PostPosted: Feb Mon 05, 2018 1:02 am
battradio@ wrote:
Hi Rip ,
Mark
Perfect! If the original is in good shape I'd prefer it over the vertical mount. I will PM you to arrange payment.
Post New Topic Post Reply  [ 7 posts ]  Moderator: Philco Fan
Users browsing this forum: Clutter, glue_ru, Paul R. Rehkopf and 7 guests
