It is currently Jul Fri 19, 2019 8:49 am
 Post subject: Schematic Conventions for Capacitors
PostPosted: Apr Sun 14, 2019 7:28 pm
To continue a topic from a test equipment question, but pertaining to parts rather than equipment:
Does anyone know if there ever was a "conventional" way to draw a capacitor? As noted in the Eico thread, electrolytics were "usually" shown with the curved side as the negative, with a + by the straight side. But this was reversed in schematics enough times that I wonder if there ever was any attempt to standardize on it.
This also pertains to the outer foil in non electrolytic caps as well. But I really never paid too much attention to which was "conventional" ... was the straight side, or the curved side, "supposed" to be the outer foil? Or, more likely, was it just up to the draftsman or the manufacturer of the equipment to decide on a case by case basis?
www.bbtvtestequipment.com
 Post subject: Re: Schematic Conventions for Capacitors
PostPosted: Apr Sun 14, 2019 9:36 pm
There are "European" standards and there are "U.S." standards.
Pick your needs:
https://www.google.com/search?q=capacit ... 83&bih=732
PostPosted: Apr Sun 14, 2019 11:05 pm
Cap symbols have been pretty standard for at least the last 75 years or so, and I think there were EIA standards starting in the early 30s.
As for orientation, I suspect those may have simply been oversights.
PostPosted: Apr Sun 14, 2019 11:26 pm
I suggest determining polarity based on the rectifier cathode.
That never lies.
If you expect schematics to always be 100% correct, you're in for a major attitude shift.
One common issue often encountered is the cap's positive grounded to chassis. This happens when the cap's negative goes to the HV winding CT and there are dropping resistances.
the HV winding CT is always the most negative point in the power supply.
PostPosted: Apr Mon 15, 2019 12:09 am
Barry,
Do you like banging your head ? :D
The are numerous conventions for drawing caps. There will never be a unified single standard agreement among thousands of electronic device manufactures as to which one to use on "their" schematics, regardless of which generation they come from. You can generalize and say the curved side, or the U shape (Philco) usually represents this or that polarity, but you or the schematic you find will be wrong too often to be reliable.
The reality is that you must understand what polarity the circuit location is established as. For vintage radios, there are some rules of thumb that help greatly when making the decision. You only need match one rule of thumb in the list to properly orient the cap.
Most cap replacement polarity decisions are straight forward due to some simple rules.
1-the center tap of the power transformer is always the most negative point in the radio power supply.
2-the cathode of the rectifier is always the most positive point.
3-if a cap lead goes to the plate of the output tube, it is positive.
PostPosted: Apr Mon 15, 2019 3:35 am
Barry, Do you like banging your head ? :D
Well, if I don't do it, someone else will ;-)
PostPosted: Apr Mon 15, 2019 11:23 am
I expect to see the straight line as the positive side with a + symbol there also. Not sure I have ever seen the positive side indicated as the curved side, but I guess it has happened. Maybe I will take a look at the Eico thread to see what you are talking about.
I don't think I have ever seen anything special on a schematic indicating foil side, but it is very straight forward to determine the lower potential side for foil, so they probably never saw a need to indicate it.
PostPosted: Apr Mon 15, 2019 9:30 pm
Getting back to symbols rather than circuit connections, these are the symbols I've standardized on in my schematics:
― R. A. Heinlein
PostPosted: Apr Mon 15, 2019 10:30 pm
I agree with those John. I use the same on my schematics.
