It is currently Feb Tue 18, 2020 8:37 am
 Post subject: car radio Vibrator Bendix part Substitute question
PostPosted: Sep Thu 12, 2019 4:16 am
Hello Guys
Well I need a Vibrator for a Bendix car radio from a 1956 ford that have been
working on.
It uses a vibrator which is a Bendix part no. C-221139-1 or a Mallory part no. G883 .
My question is the customer brought over a used Delco part no. 249705-2 .
will that Delco sub for the Bendix .
Sincerely Rich
 Post subject: Re: car radio Vibrator Bendix part Substitute question
PostPosted: Sep Thu 12, 2019 6:58 am
Hi Rich
the 6BF uses a 3 pin 12 v neg ground vibrator. All the other 56 uses a 4 pin 12 volt neg ground vibrator. Kind of an odd duck.
I have a Solid State 4 pin 12 volt neg ground ones which are not made anymore
billn
PostPosted: Sep Thu 12, 2019 1:22 pm
Hello Bill,
both of these vibrators are 3 pin 12 volts
PostPosted: Sep Thu 12, 2019 6:29 pm
As far as I know, all three pin vibrators are twelve volts and are wired the same internally. Reed is center pin and the other two are P1 and P2. It makes no difference if P1 and P2 are reversed as the vibrator cares nothing about polarity. Denis
PostPosted: Sep Sat 14, 2019 3:37 am
Hello Dennis,
thanks
PostPosted: Sep Sun 22, 2019 5:00 am
Hello guys
the sams schematic shows Mallory G883 as a replacement Vibrator?
I have a NOS Mallory part no. G1602 they are both 3 pin 12 volt units will the 1602 replace the 833.
Sincerely rich
PostPosted: Sep Sun 22, 2019 5:53 pm
radiorich wrote:
Hello guys
the sams schematic shows Mallory G833 as a replacement Vibrator?
Sincerely rich
I believe you meant Mallory G883? The 1957 Mallory catalog shows both G883 and G1602 as replacements for your radio.
Meade
PostPosted: Sep Sun 22, 2019 5:56 pm
Hello Mag,
yes that the one I have a NOS Mallory part no. G1602
thanks MAG I fixed the typo
PostPosted: Sep Fri 27, 2019 11:04 pm
The ā€œGā€ prefix for Mallory part numbers means 12 volt. Three pin vibrators are 12 volt. Denis
PostPosted: Sep Sat 28, 2019 4:51 am
Hello Dennis,
thanks anyway I tried vibrator in the radio no luck but the vibrator does work and I another one to and the same thing
