It is currently Oct Wed 20, 2021 8:09 am
 Post subject: Tubular ceramic capacitors
PostPosted: Sep Mon 20, 2021 10:34 pm
My Schaub Lorenz Rialto Stereo 10 has a number of tubular ceramic capacitors. A few questions.
1) Are these generally reliable?
2) They are usually low pF values, the same radio also uses low pF value polystyrene caps. Why sometimes polystyrene and sometimes tubular ceramic?
3) if they do need replacing would silver mica be suitable?
 Post subject: Re: Tubular ceramic capacitors
PostPosted: Sep Mon 20, 2021 10:40 pm
I have never seen a tubular ceramic capacitor that had become defective in the way that paper capacitors do. I have seen a couple that have broken in the middle of the bodies.
PostPosted: Sep Mon 20, 2021 10:56 pm
If this type of cap isn't broken, it has a 99% chance of being good. The ceramics are usually employed where the value needs to be stable with temperature changes. That is almost always in a tuned circuit. For those applications, a silver mica is a good replacement.
There are applications where the ceramic cap is supposed to change value with temperature to compensate for other parts in the resonant circuit. The schematic or parts list will usually indicate when a special temperature coefficient is needed.
Jay
PostPosted: Sep Mon 20, 2021 11:23 pm
Don't mess with them. They are some of the most reliable parts ever.
RRM
PostPosted: Sep Mon 20, 2021 11:59 pm
I agree they are extremely reliable. Don't move them, don't desolder the leads, don't attempt to test them, just leave them exactly how you found them until and unless you have an operational problem that can be traced to one.
You are also not likely to be able to find replacements for any that have special temperature compensating characteristics.
PostPosted: Sep Tue 21, 2021 1:52 am
^^^^ All the above is correct: these tubular ceramic caps are ultra reliable if not put under mechanical stress. Just leave them as they are.
Since their tempco characteristics are unknow and could be an important factor in some parts of the circuit replacement could be problematic and is not recommended.
PostPosted: Sep Tue 21, 2021 2:14 am
Polystyrene capacitors are also extremely reliable unless they are abused. Leave them alone as well. Be careful not to touch them with a soldering iron; they melt. Be careful not to get any solvent on them: they dissolve.
