Forums :: Web Resources :: Features :: Photo Gallery :: Vintage Radio Shows :: Archives
It is currently Jun Thu 08, 2023 7:36 pm
Post New Topic Post Reply  [ 25 posts ]  Go to page Previous  1, 2
 Post subject: Re: Tube ID
PostPosted: May Wed 24, 2023 6:19 pm
So you are saying it is no good at all?
PostPosted: May Thu 25, 2023 5:21 am
Pretty much so. :(
Just to be sure, you could put a 1 ohm several watt resistor in series with the filament and read the voltage across it to verify that it is drawing current, although the tube should feel warm after awhile.
PostPosted: May Fri 26, 2023 1:23 am
Did you test it for shorts and gas?
PostPosted: May Fri 26, 2023 8:41 am
How does one test for shorts if not sure of tube, to set tube data for test?
PostPosted: May Fri 26, 2023 7:06 pm
Any triode on a 4-pin UX base has the same pinout. The fat pins are the filament, pin 2 is the plate and 3 is the grid. Set it up in the tester as a 45 and run through your shorts tests.
