It is currently Sep Mon 20, 2021 10:20 pm
Post New Topic Post Reply  [ 38 posts ]  Go to page 1, 2  Next
 Post subject: Grinding crystals
PostPosted: Jan Mon 07, 2013 8:25 pm
Don't know if this is the proper forum for this topic, so direct me elsewhere if I am in the wrong place.
I am looking at grinding some FT-243 crystals to the lower end of 40 and 80 meters for use in a Knight T-60 transmitter. I'll get basic in my questions:
1. You grind to a lower freq, correct?
2. What type of compound is best for the job?
3. What is a typical range in freq that the crystal can be effectively ground? I am looking at crystals that are around 100-300 khz high.
4. What has been your proven technique for accomplishing the job?
Thanks in advance,
Marc
 Post subject: Re: Grinding crystals
PostPosted: Jan Mon 07, 2013 8:29 pm
Grinding a crystal reduces its thickness, and raises the mechanical resonant point. Grinding will RAISE the frequency, you can't lower it.
Most hams would be lucky to move a crystal several kHz before running into difficulty. You have to be extremely careful to maintain the parallel surfaces of the crystal slab when grinding them down. Most hams used a figure eight pattern when lapping crystals. I'm not sure what would be the best grinding compound; so I'll let a few others chime in... but a 100 kHz shift is an ambitious undertaking.
Pete
PostPosted: Jan Mon 07, 2013 8:38 pm
Peter, I agree and have actually tried grinding FT-243 military crystals to try to fudge them into the ham bands (back in my Novice days). Always ended up with a failed crystal long before reaching my objective.
I had a bucket full of military crystals so figured it was worth a try, but it was a waste of time. I think I managed to move some 20 or 30 kHz, but that's about it.
Curtis Eickerman
PostPosted: Jan Mon 07, 2013 8:45 pm
Thanks, gents, for the prompt replies. I may try it just for fun, but finding crystals cut to the lower end of 80 or 40 meters is a bit tough. I found a couple on ebay and they were pretty proud of them at $15 ea. Perhaps I am naive, but that seems a bit high. Any suggestions as to where I might find crystals would be greatly appreciated.
Marc
PostPosted: Jan Mon 07, 2013 8:57 pm
Well, I may have been a little too critical of today's pricing. I found a 7025 khz for $10, and it covers 40, 20, and 15, and 10 meters pretty well. May still try the grinding thing in my spare time.
Thanks for the tips,
Marc
PostPosted: Jan Mon 07, 2013 9:01 pm
I've always bought my crystals from International Crystal Manufacturing in Oklahoma City www.icmfg.com
Give them the equipment model number or a homebrew schematic and they'll send you the right crystal.
Great folks to deal with.
- Leigh
73 de W3NLB
http://www.AtwaterKent.info
PostPosted: Jan Mon 07, 2013 9:47 pm
You can go up in frequency grinding crystals. Very important to keep the crystal flat. Try grinding with powder, we used to use Ajax, and a little water. Do this on a piece of glass.
If you don't grind perfectly flat and keep surfaces parallel crystals will lose activity. At some point they no longer oscillate.
PostPosted: Jan Mon 07, 2013 9:52 pm
Leigh wrote:
I've always bought my crystals from International Crystal Manufacturing in Oklahoma City http://www.icmfg.com
I don't think they do any FT-243 (almost HC 17/U) packages anymore (at least not listed), but you may be able to convert HC 50/U or 51/U that they do sell by using this procedure http://k4che.com/HC%206%20Convert%20pag ... 20page.htm (note HC 6/U, HC 33/U HC 50/U and HC 51/U all have almost the same spacing as the old FT 243, but just not the proper pin diameter or length).
Here is a lot of information about the package sizes and pin spacings for various crystal holders http://www.af4k.com/crystal_holders.htm .
Ultimately you are trying to get 0.5" pin spacing for .093" diameter pins if I remember correctly.
Curtis Eickerman
PostPosted: Jan Mon 07, 2013 11:11 pm
Hi Curtis,
I don't think anybody has made real FT-243 holders since WWII.
The pin diameter and spacing are what matter.
I have one in hand at the moment. Spacing measures .484" with a diameter of .093".
That seems odd, but the measurements are correct. Perhaps it's not a real FT-243 but looks like one.
I do remember that the FT-243 will fit in an octal socket (skipping one hole).
So I measured an octal socket and it does come out to 0.500" c-c.
Don't know where the discrepancy is. I remembered the spacing as 0.500" also.
- Leigh
73 de W3NLB
PostPosted: Jan Mon 07, 2013 11:39 pm
Yeah, the HC 17/U , CR 5/U or CR 6/U were the more modern equivalent for the FT 243 with about 0.485" spacing and .093" pins. The .015" difference on the spacing doesn't matter on the typical sockets that have more slop... I mean "allowance" than that. :)
I think all of these are also now obsolete.
Curtis Eickerman
PostPosted: Jan Tue 08, 2013 12:05 am
I tried grinding FT-243 xtals in my Novice days and couldn't really get any good results.
Read an article in QST about lowering xtal frequency. You simply rub one face of the crystal with a soft lead pencil and load it down with graphite... well, that was the theory. It would drop the frequency a few kcs. for a while. Was not a stable solution.
Some QRP transmitter designs use an "adjustable" circuit to change frequency a few Kcs. by varying the capacitance in series with the crystal.
PostPosted: Jan Tue 08, 2013 12:38 am
My dad used to grind cystals using a plate glass window and toothpaste. He sometimes use Cloverdale valve grinding paste XXXX fine grit.Told me both worked well.IIsometimes still see thoses old xtals at out Antique radio swap meets but not like i used to.Sprman
Be happy ,enjoy life as its so short!
PostPosted: Jan Tue 08, 2013 1:36 am
Hi,
Just chiming in with nothing but dittos. My grinding success has been rather pitiful. 20-30 kcs before I ruin it. And that's using all the various 'approved' methods. Some guys claim much better success but I don't think we regular guys can do it. $10-15 bux for an original FT-243 isn't a bad price these days - particularly if its a desirable frequency. You can get a nice VFO for the cost of a few rocks!
The beatings will continue until the morale improves
PostPosted: Jan Tue 08, 2013 2:42 am
Marc,
I found a little more information...
http://www.antiqueradios.com/forums/viewtopic.php?t=5470
http://www.hayseed.net/~jpk5lad/K5LAD%20Memories/Vols%2026-30/MemoriesVol28.htm
http://home.netcom.com/~wa4qal/crystal.htm
At wa4qal, extensive documentation of the progress of the grinding process has been documented. An impressive change of frequency of greater than 1.2mhz :shock:
I have an old photocopy of a reprint of the November 1957 CQ article "How to GRIND Crystals". There are a couple of useful ideas in the article that are not mentioned in anything I found on the web. I can scan it and send it as an image or a pdf to your email address.
FWIW I ground crystals some 50 years ago taking many short cuts. Out of three crystals, two failed to oscillate and one moved somewhat but lost a lot of its activity. I recall I made the mistake of grinding both sides :roll:
GL Marc
Chas
WA1JFD
PostPosted: Jan Tue 08, 2013 3:53 am
I transmitted FSK (Frequency shift keying). Used diode switching and caps along with a crystal. Almost all crystals would shift 425 cycles, some to around 1k. Don't remember any shifting much more than that.
PostPosted: Jan Tue 08, 2013 6:10 am
Chas,
Thanks for the links. I'll keep this information handy. Will probably try it at least once to see how it works out.
Marc
PostPosted: Jan Tue 08, 2013 7:10 am
The pencil lead trick will pull down the frequency, but the trade off is always reduced crystal activity.
Pete
PostPosted: Jan Tue 08, 2013 10:06 pm
Don't forget to wash the crystal carefully after grinding to remove all the "crud" before trying it back in the holder.
I have seen several xtal grinding articles, most of what was written was mentioned above.
One article mentioned using Comet ā„¢ cleanser for the grinding compound, besides some mentioning the tooth paste.
FrankB
WB7ELC
"The average family has 2.5 children. Where is the other .5 child?"
PostPosted: Jan Tue 08, 2013 10:53 pm
Comet works, so does tooth paste. Tooth paste is slower. A person could start with Comet and finish off with tooth paste.
PostPosted: Jan Wed 09, 2013 3:16 am
It's always been a mystery to me how quartz could possibly be abraded with softer materials like household
cleansers or toothpaste.
