Page 1 of 1
[ 6 posts ] |
Author |
doc612
Post subject: Need sub help- again Posted: Mar Wed 14, 2018 3:39 pm |
Joined: Feb Sat 28, 2015 10:50 pm Posts: 831 Location: Decatur Alabama
I just acquired a Silvertone 4485 that has a 6N6 as an output tube. What, if any, tube can I use as a substitute?
Top |
AuroraOldRadios
Post subject: Re: Need sub help- again Posted: Mar Wed 14, 2018 3:46 pm |
Member |
Joined: Jul Sun 09, 2006 3:11 am Posts: 7205 Location: Aurora, CO 80013
A quick search of Ebay turns up many 6N6G tubes. No need for a sub.
Top |
doc612
Post subject: Re: Need sub help- again Posted: Mar Wed 14, 2018 4:00 pm |
Well, I can get one from my radio club on Saturday. I was just working on it today and wanted to see if there was a possibility of getting it to play.
Top |
AuroraOldRadios
Post subject: Re: Need sub help- again Posted: Mar Wed 14, 2018 4:27 pm |
Member |
Top |
pixellany
Post subject: Re: Need sub help- again Posted: Mar Wed 14, 2018 6:28 pm |
Member |
Joined: Jul Mon 26, 2010 8:30 pm Posts: 29157 Location: Annapolis, MD
One good place for subs: http://www.nj7p.org/Tubes/SQL/Tube_query.php?Type=6N6GNote that I had to enter 6N6 GDon't spend a lot of calories on this--Bob Dobush has 6N6s for $7 used / $12 new. (6AB6 is a different story--2 of my suppliers don't list it--I found one new one for $35)
_________________ -Mark "Voltage is fun to watch, but it's the CURRENT that does the work."
Top |
Norm Leal
Post subject: Re: Need sub help- again Posted: Mar Wed 14, 2018 6:34 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 30748 Location: Livermore, CA
Use 6V6, 6K6 or 6F6 tubes. When you do this lift connection to pin #8 and add a 470 ohm resistor in series with this wire. Best if you also connect a 10 - 25mf @ 50 volt cap across the resistor. You can use the radio with any of these tubes if you don't have a 6N6.
Advantage of 6N6, didn't require the above bias components.
_________________ Norm
Top |
Page 1 of 1
[ 6 posts ] |
Users browsing this forum: No registered users and 13 guests |
