It is currently Mar Sat 23, 2019 12:14 pm
 Post subject: Ballast Tube Question
PostPosted: Feb Sat 09, 2019 8:02 pm
Hi:
Recently picked up a Air King Model 257 all tubes checked out okay except ballast tube originally came with a M49HG however it was substituted out with a universal 23-55-F that has no reading across pins 2-3 was wondering if anybody had any experience taking one of these apart before I make a attempt at it. I'm thinking I might be able to repair it.
Sidevalvebob
 Post subject: Re: Ballast Tube Question
PostPosted: Feb Sat 09, 2019 11:47 pm
Your tube line up is 68V at 0.3amps. The ballast tube is dropping 52V for a 120V line voltage. You could replace the ballast tube with an 8uf 250vac rated capacitor. An 8uf capacitor will drop about 60VAC at 0.3ma, providing 60VAC for the tube heaters. That is slightly lower than the 68V they are rated for, but it won't harm them. Using an AC capacitor will eliminate the heat of the ballast tube.
If you do this, disconnect pin 3 so the ballast tube is no longer in the circuit. Otherwise if some plugs in a good ballast in the future, one or more tubes will burn out in a short time.
Use something like this https://www.amazon.com/PODOY-CBB61-Ceiling-Capacitor-250VAC/dp/B0143VJN40
PostPosted: Feb Sun 10, 2019 12:16 am
You can keep the radio wired as is. Use the shell of the ballast tube and base. Here's a how to from my pal Jeff at the Antique Radio Store. About half way down the page. For dial light use #44 bulb with 47 Ohm resistor across the bulb in series with the heater string.
http://www.oldradiosrus.com/build.html
Capacitor to use.
https://www.digikey.com/product-detail/ ... ND/4694508
PostPosted: Feb Sun 10, 2019 9:24 pm
Thank you nash and thunderbird281 for your advice and recommendations late last night was able to remove top cover off the ballast tube. Interesting how they made these, the mica board acts as a insulator as well as a thermal conductor. I included two pictures, first picture shows resistance wire comming off pin 2 it's separated at the board terminal and broken near the top of the insulating board. Picture two shows the resistance wire coming from pin 3 and where the wire has separated. Not sure if this can be repaired if not will follow your recommendations. will get the resistors and capacitor on the next order I put in.
PostPosted: Feb Sun 10, 2019 11:00 pm
Not fixabe. Can't solder wire. Also all the wire is fatigued .
PostPosted: Feb Tue 12, 2019 12:50 am
Also the wire gets hot, solder will melt. :shock:
I like things that light up, tubes, bulbs, LEDs, whatever, and things that make noise.
PostPosted: Feb Tue 12, 2019 3:56 am
FYI, American Radio History has the two Ballast Tube manuals:
Reference:
https://www.americanradiohistory.com/Ar ... ok-opt.pdf
and substitution:
https://www.americanradiohistory.com/Ar ... de-opt.pdf
Brian
PostPosted: Feb Tue 12, 2019 2:30 pm
Thank you thunderbird281, Number 6, Findm-Keepm for all your help, these ballast tubes remind me of a mini toaster lol. I've added the ballast tube files to my collection and now have a list of substitute tubes. Got my fingers crossed there is a hamfest in Burlington Ontario Canada this weekend hopefully I will come across another tube or the resistors and capacitor I need for the conversion. Even if I find another tube I will do the conversion on my old tube regardless.
Thanks Again
Sidevalvebob
PostPosted: Feb Tue 12, 2019 3:46 pm
nash wrote:
Your tube line up is 68V at 0.3amps. The ballast tube is dropping 52V for a 120V line voltage. You could replace the ballast tube with an 8uf 250vac rated capacitor. An 8uf capacitor will drop about 60VAC at 0.3ma, providing 60VAC for the tube heaters. l]
A nitpick here, if I may. The capacitor voltage is out of phase with the resistive load of the filaments, so the two add as vectors:
Vc = cap voltage
Vr = voltage
Supply = 120 = square root ( Vc^2 + Vr^2)
OR
Vc = square root (120^2 - Vr^2)
<<same formula to get Vr, when you know Vc---just swap the two>>
The drop on the capacitor:
Xc = 0.159 / (f*C) = 0.159 / 480E-6 = 331 ohms
at 0.3mA, that gives us ~ 100 volts on the cap, so the load voltage will be square root( 120^2 - 100^2 ) = ~66 volts
-Mark http://pixellany.com
PostPosted: Feb Wed 13, 2019 9:39 pm
Thank You pixellany for your input the information is very much appreciated.
Sidevalvebob
