It is currently Mar Sat 23, 2019 11:40 am
 Post subject: Can you identify this capacitor value?
PostPosted: Feb Tue 12, 2019 7:00 pm
I've read countless explanations online as to how to read these, but math isn't my thing---I don't know how to convert pf to uf, where I'm supposed to put the decimal point, etc. This one is pretty large, so I'm guessing it's paper? Thanks for any help you can give
EDIT; the lettering is right side up (not upside down) if that helps
William
 Post subject: Re: Can you identify this capacitor value?
PostPosted: Feb Tue 12, 2019 10:33 pm
What does schematic say? What is model number? Here is handy to have in favorites.
https://www.justradios.com/uFnFpF.html
Bill J.
PostPosted: Feb Tue 12, 2019 11:15 pm
100 x 100 pF = 10,000 pF = .01uF @300v.
Once you have pF, just move the decimal point to the left 6 places for uF.
PostPosted: Feb Wed 13, 2019 5:26 am
Thanks, much appreciated! The radio is a Concord 1-402, and I have the schematic for it. But they must've made running changes in production, because some of the parts values and a couple of connections are different. In this case, the part on the schematic is .05, but based on the color codes, I knew that couldn't be right
William
PostPosted: Feb Wed 13, 2019 8:05 pm
Well...if you say so. But .01 or .05 the 300V replacement is not 400V according to what the parts list indicates. The cap is not original to set.
Bill J.
PostPosted: Feb Wed 13, 2019 9:21 pm
Assuming this is an RMA/EIA code, the orange dot indicates 300v. 400v would be yellow, and it certainly doesn't look like yellow to me.
I trust what I see in sets more than schematics, especially when I can see that a component looks original to a set.
I would see what kind of voltage is across the cap as a 300v cap there might be perfectly acceptable and put in by the factory.
PostPosted: Feb Wed 13, 2019 10:27 pm
You can also tell by the soldering job that it's a replacement part. I would go by the schematic.
