Page 1 of 1
[ 7 posts ] |
Author |
hockingcountyhillbilly
Post subject: Antenna connectors Posted: Jun Thu 27, 2019 5:45 am |
Member |
Joined: Jan Thu 10, 2019 5:39 pm Posts: 131 Location: Rockbridge Ohio 43149
Does anyone have a source for this male connector? Used for antenna and speaker on an Airline I am working on, I've also seen them on Zenith TO's. (Female half also shown for reference)
Attachments: |
Top |
SHenion
Post subject: Re: Antenna connectors Posted: Jun Thu 27, 2019 5:50 am |
Joined: Feb Wed 07, 2018 6:52 pm Posts: 551 Location: Stone Mountain, GA
Looks like standard bullet crimp connectors.
There are various sizes. You can probably get them at an auto parts store. Pull the plastic sleeve off and they should look the same.
_________________ Scott. Powered by infinite improbability drive.
Top |
fifties
Post subject: Re: Antenna connectors Posted: Jun Thu 27, 2019 5:55 am |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 33343 Location: SoCal, 91387
If you are not a stickler for originality, just use a cut down nail, or a screw.
_________________ \\\\\\\\\\\\\\\\\\\\\\\\He Who Dies With The Most Radios Wins//////////////////
Top |
wazz
Post subject: Re: Antenna connectors Posted: Jun Thu 27, 2019 1:32 pm |
Member |
Joined: Jun Wed 08, 2011 2:33 am Posts: 9556 Location: Ohio 45177
Yea, something like automotive might work, or perhaps a large male Molex pin. Hard to tell the size of those from the picture. Or advertise with a WTB in case someone has some stashed back somewhere.
_________________ Reddy Kilowatt says; You smell smoke? Sorry about that!
Top |
Jim Koehler
Post subject: Re: Antenna connectors Posted: Jun Thu 27, 2019 5:06 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 6575 Location: Freeport, LI, New York 11520
Here's a tip......
Next time you're at the hardware store, get a selection of different sized pop rivets. After removing the pin, the outer part comes damn near the many pin sizes used in the old radios. An example is the battery setups I like to make for my Transoceanics. The pins used are right-sized for the chassis plug and are easily solderable. They make for the neat job.
...Jim
_________________ "Resistance may be futile but capacitance has potential"
Top |
Yarehobbiesso$
Post subject: Re: Antenna connectors Posted: Jun Thu 27, 2019 5:17 pm |
Joined: Feb Thu 28, 2019 7:48 pm Posts: 406 Location: Lawrenceville, Illinois 62439
Hardware store, Harbor Freight, your local electrical supplier, etc. Look for a $7.99 terminal kit. Usually comes with ring, spade, bullet, etc. in a few different sizes. I've found the blue bullet work just fine on Motorola, Zenith, etc. speaker connectors. We used these a lot back in the car stereo install days. Dan
Attachments: |
Top |
Post subject: Re: Antenna connectors Posted: Jun Fri 28, 2019 1:38 am |
Member |
Thank you everyone, I found some 4mm bullet crimp connectors that are perfect.
Top |
Page 1 of 1
[ 7 posts ] |
Who is online |
Users browsing this forum: Jack Cureton and 4 guests |
